The error shown in the last line should be solved in the "latest" release being built right now.mib2berlin wrote: Tue Feb 18, 2020 12:51 am EDIT: Got not exactly the same errors:Code: Select all
C:\Users\pepo\Downloads\blender-2.82-windows64\2.82\scripts\addons\BlendLuxCore\bin>python pyluxcoretools.zip netnodeui ImportError: numpy.core.multiarray failed to import ImportError: numpy.core.umath failed to import Traceback (most recent call last): File "C:\Users\pepo\AppData\Local\Programs\Python\Python37\lib\runpy.py", line 193, in _run_module_as_main "__main__", mod_spec) File "C:\Users\pepo\AppData\Local\Programs\Python\Python37\lib\runpy.py", line 85, in _run_code exec(code, run_globals) File "pyluxcoretools.zip\__main__.py", line 71, in <module> File "pyluxcoretools.zip\pyluxcoretools\pyluxcorenetnode\ui.py", line 144, in main File "pyluxcoretools.zip\pyluxcoretools\pyluxcorenetnode\ui.py", line 135, in ui File "pyluxcoretools.zip\pyluxcoretools\pyluxcorenetnode\ui.py", line 46, in __init__ File "pyluxcoretools.zip\pyluxcoretools\pyluxcorenetnode\mainwindow.py", line 196, in setupUi AttributeError: 'PySide2.QtWidgets.QAction' object has no attribute 'activated'
Regarding the numpy errors, have you installed numpy on your system?
You can do that with:
pip install numpy
