What is new in LuxCore API v2.0 ?
Re: What is new in LuxCore API v2.0 ?
Added the support for glass dispersion.
Added the support for dynamic edit of halt rendering conditions.
Re: What is new in LuxCore API v2.0?
Added the support for Film outputs "safe save".
Added the pyluxcoreconsole and pyluxcoremerge tools.
Improved glass and archglass sampling strategy: viewtopic.php?f=2&t=45&p=605#p604
Added the support for Embree multi-segments motion blur.
I'm working on convergence based adaptive sampling for the new RANDOM and SOBOL sampler. The first result are very interesting:
From left to right:
- the normal rendering output;
- the new SAMPLECOUNT AOV (i.e. the sample count for each pixel, darker means less samples, brighter means more);
- the new the CONVERGENCE AOV (i.e. how for from the convergence threshold is a pixel, darker means near and less noise, brighter means far and more noise).
As you see the SAMPLECOUNT and CONVERGENCE images pretty much match: the sampler is using more samples where they are more needed.
With the old RANDOM/SOBOL sampler the middle image would be just flat gray as each pixel receives the same amount of samples no matter what.
:D :D :D hehe you're blessing US. :twisted: :twisted: Scuderia Luxcore in total Red mod :twisted: :twisted: .
you make people feel like programing is so fun. will never give up with my Python course.
So if i understand well this can be used for any mod at the end ?
Thannk you !
Sharlybg wrote: Thu Feb 01, 2018 9:13 am So if i understand well this can be used for any mod at the end ?
Yes, however BIDIRCPU is a bit in its own league and doesn't make very much sense to use anything else but METROPOLIS with BIDIR.
I'm working on the new volume rendering code. this is a cube with a volume defined by an FBM procedural texture:
