Page 2 of 2
Re: LuxCoreRender v2.0alpha6 released
Posted: Wed Mar 07, 2018 8:23 am
by acasta69
Maybe the OCL zip contains the no-OCL binaries for some reason?
File size in the two archives looks identical, and here is the message from blender when trying to use an OCL engine:
- Untitled.png (4.42 KiB) Viewed 27764 times
Posted: Wed Mar 07, 2018 9:07 am
Yes, for some reason, the OpenCL-less version executables ended in the OpenCL .zip. I have updated the stand alone version and Blender version too. They should now work fine.
Posted: Wed Mar 07, 2018 9:48 am
by marcatore
Now it's working.
Thank you.
Using a scene I'm using for my tests, the F12 rendering process seems really long comparing the previous alpha.
Anyone else?
EDIT: nevermind... I've reload the scene and it seems ok with normal compiling time.
I'll evaluate with other tests.
Sorry
Posted: Wed Mar 07, 2018 9:50 am
by Asticles
Yes! Thanks for this great software!
Posted: Wed Mar 07, 2018 10:22 am
marcatore wrote: Wed Mar 07, 2018 9:48 am
Anyone else?
Alpha5 had the "not inline" trick to speed up compilation times on NVIDIA. However the trick crash the NVIDIA compiler in some cases, so the problem is choosing between something that work (alpha6) and something that sometime doesn't but it is faster to compile (alpha5). There isn't a good choose
Posted: Wed Mar 07, 2018 10:32 am
by Asticles
IMHO, stability is much better, if you want to work in production.
Regards
Posted: Wed Mar 07, 2018 11:52 am
by jensverwiebe
Linux users can still test my optimized builds, no crashing, no instabilities so far.
Posted: Wed Mar 07, 2018 12:29 pm
jensverwiebe wrote: Wed Mar 07, 2018 11:52 am
Does it render LuxMark Mic (or similar scenes) ?
Posted: Fri Mar 09, 2018 5:52 am
by 400ml
Everything is working well on my end, just downloaded and installed today.
