Page 2 of 2
Re: Error: OpenCl viewport render doesn't work
Posted: Mon Jul 22, 2019 9:10 am
kintuX wrote: Mon Jul 22, 2019 5:52 am
RT OCL is broken here too.
But in my case Blender simply stops responding. Need to force close.
It doesn't sound as the same problem, does it happen with the new fix ? Only with RTPATHOCL and not with with PATHOCL ?
Posted: Mon Jul 22, 2019 1:35 pm
Dade wrote: Mon Jul 22, 2019 9:10 am
Happens only with RT OCL in viewport. (Yesterday's build, i see there are now couple of new fixes in - will test again)
I saw this post and some other mentions and decided to give it a test.
I rarely use it, since with decent CPU core count it's just impractical for fast previews.
Got this from console:
[LuxRays][63.672] [Device GeForce GTX 1070 Intersect] SampleData buffer size: 1152Kbytes
[LuxRays][63.672] [Device GeForce GTX 1070 Intersect] PathVolumeInfo buffer size: 6336Kbytes
[LuxRays][63.672] [Device GeForce GTX 1070 Intersect] DirectLightVolumeInfo buffer size: 6336Kbytes
[LuxRays][63.672] [Device GeForce GTX 1070 Intersect] Pixel Filter Distribution buffer size: 33Kbytes
[LuxCore][63.672] [PathOCLBaseRenderThread::0] Defined symbols: -D LUXRAYS_OPENCL_KERNEL -D SLG_OPENCL_KERNEL -D RENDER_ENGINE_RTPATHOCL -D PARAM_RAY_EPSILON_MIN=1.000000e-05f -D PARAM_RAY_EPSILON_MAX=1.000000e-01f -D PARAM_LIGHT_WORLD_RADIUS_SCALE=1.050000e+00f -D PARAM_ACCEL_MBVH -D PARAM_FILM_RADIANCE_GROUP_0 -D PARAM_FILM_RADIANCE_GROUP_1 -D PARAM_FILM_RADIANCE_GROUP_COUNT=2 -D PARAM_ENABLE_TEX_CONST_FLOAT -D PARAM_ENABLE_TEX_CONST_FLOAT3 -D PARAM_ENABLE_TEX_IMAGEMAP -D PARAM_ENABLE_TEX_NORMALMAP -D PARAM_ENABLE_TEX_FRESNELCOLOR -D PARAM_ENABLE_TEX_FRESNELCONST -D PARAM_ENABLE_MAT_MATTE -D PARAM_ENABLE_MAT_ROUGHMATTE -D PARAM_ENABLE_MAT_MIRROR -D PARAM_ENABLE_MAT_GLASS -D PARAM_ENABLE_MAT_ARCHGLASS -D PARAM_ENABLE_MAT_NULL -D PARAM_ENABLE_MAT_MATTETRANSLUCENT -D PARAM_ENABLE_MAT_ROUGHMATTETRANSLUCENT -D PARAM_ENABLE_MAT_GLOSSY2 -D PARAM_ENABLE_MAT_GLOSSY2_ABSORPTION -D PARAM_ENABLE_MAT_GLOSSY2_INDEX -D PARAM_ENABLE_MAT_GLOSSY2_MULTIBOUNCE -D PARAM_ENABLE_MAT_METAL2 -D PARAM_ENABLE_MAT_ROUGHGLASS -D PARAM_ENABLE_MAT_CLEAR_VOL -D PARAM_ENABLE_MAT_HOMOGENEOUS_VOL -D PARAM_ENABLE_MAT_GLOSSYTRANSLUCENT -D PARAM_HAS_PASSTHROUGH -D PARAM_CAMERA_TYPE=0 -D PARAM_HAS_INFINITELIGHT -D PARAM_HAS_CONSTANTINFINITELIGHT -D PARAM_HAS_SKYLIGHT2 -D PARAM_HAS_SUNLIGHT -D PARAM_HAS_SHARPDISTANTLIGHT -D PARAM_HAS_DISTANTLIGHT -D PARAM_HAS_POINTLIGHT -D PARAM_HAS_MAPPOINTLIGHT -D PARAM_HAS_SPOTLIGHT -D PARAM_HAS_PROJECTIONLIGHT -D PARAM_HAS_LASERLIGHT -D PARAM_HAS_TRIANGLELIGHT -D PARAM_HAS_SPHERELIGHT -D PARAM_HAS_MAPSPHERELIGHT -D PARAM_HAS_ENVLIGHTS -D PARAM_HAS_IMAGEMAPS -D PARAM_IMAGEMAPS_PAGE_0 -D PARAM_IMAGEMAPS_COUNT=1 -D PARAM_HAS_IMAGEMAPS_BYTE_FORMAT -D PARAM_HAS_IMAGEMAPS_HALF_FORMAT -D PARAM_HAS_IMAGEMAPS_FLOAT_FORMAT -D PARAM_HAS_IMAGEMAPS_1xCHANNELS -D PARAM_HAS_IMAGEMAPS_3xCHANNELS -D PARAM_HAS_IMAGEMAPS_WRAP_REPEAT -D PARAM_HAS_BUMPMAPS -D PARAM_HAS_VOLUMES -D SCENE_DEFAULT_VOLUME_INDEX=4294967295 -D PARAM_MAX_PATH_DEPTH=9 -D PARAM_MAX_PATH_DEPTH_DIFFUSE=6 -D PARAM_MAX_PATH_DEPTH_GLOSSY=7 -D PARAM_MAX_PATH_DEPTH_SPECULAR=7 -D PARAM_RR_DEPTH=3 -D PARAM_RR_CAP=5.000000e-01f -D PARAM_SQRT_VARIANCE_CLAMP_MAX_VALUE=1.000000e+05f -D PARAM_IMAGE_FILTER_TYPE=2 -D PARAM_IMAGE_FILTER_WIDTH_X=1.500000e+00f -D PARAM_IMAGE_FILTER_WIDTH_Y=1.500000e+00f -D PARAM_IMAGE_FILTER_PIXEL_WIDTH_X=1 -D PARAM_IMAGE_FILTER_PIXEL_WIDTH_Y=1 -D PARAM_IMAGE_FILTER_GAUSSIAN_ALPHA=2.000000e+00f -D PARAM_USE_PIXEL_ATOMICS -D PARAM_HYBRID_BACKFORWARD -D PARAM_HYBRID_BACKFORWARD_GLOSSINESSTHRESHOLD=1.000000e-01f -D PARAM_SAMPLER_TYPE=3 -D PARAM_ELVC_GLOSSINESSTHRESHOLD=0.0f -D PARAM_RTPATHOCL_PREVIEW_RESOLUTION_REDUCTION=4 -D PARAM_RTPATHOCL_PREVIEW_RESOLUTION_REDUCTION_STEP=8 -D PARAM_RTPATHOCL_RESOLUTION_REDUCTION=1 -D LUXCORE_NVIDIA_OPENCL
[LuxCore][63.672] [PathOCLBaseRenderThread::0] Compiling kernels
[LuxCore][63.813] [PathOCLBaseRenderThread::0] PathOCL kernel compilation error
ERROR clBuildProgram[CL_BUILD_PROGRAM_FAILURE]:
<kernel>:9414:30: warning: passing 'const __global float *' to parameter of type '__global float *' discards qualifiers
VSTORE3F(origP + uu * dpdu, &hitPoint->p.x);
<kernel>:94:47: note: passing argument to parameter 'p' here
void VSTORE3F(const float3 v, __global float *p) {
<kernel>:9415:17: error: read-only variable is not assignable
hitPoint->uv.u += uu;
<kernel>:9416:46: warning: passing 'const __global float *' to parameter of type '__global float *' discards qualifiers
VSTORE3F(normalize(origShadeN + uu * dndu), &hitPoint->shadeN.x);
<kernel>:9423:30: warning: passing 'const __global float *' to parameter of type '__global float *' discards qualifiers
VSTORE3F(origP + vv * dpdv, &hitPoint->p.x);
<kernel>:9424:17: error: read-only variable is not assignable
hitPoint->uv.u = origUV.s0;
<kernel>:9425:17: error: read-only variable is not assignable
hitPoint->uv.v += vv;
<kernel>:9426:46: warning: passing 'const __global float *' to parameter of type '__global float *' discards qualifiers
VSTORE3F(normalize(origShadeN + vv * dndv), &hitPoint->shadeN.x);
<kernel>:9432:18: warning: passing 'const __global float *' to parameter of type '__global float *' discards qualifiers
VSTORE3F(origP, &hitPoint->p.x);
<kernel>:9433:19: warning: passing 'const __global float *' to parameter of type '__global float *' discards qualifiers
VSTORE2F(origUV, &hitPoint->uv.u);
<kernel>:82:47: note: passing argument to parameter 'p' here
void VSTORE2F(const float2 v, __global float *p) {
<kernel>:14913:20: warning: passing 'const __global float *' to parameter of type '__global float *' discards qualifiers
VSTORE3F(shadeN, &hitPoint->shadeN.x);
<kernel>:14914:18: warning: passing 'const __global float *' to parameter of type '__global float *' discards qualifiers
VSTORE3F(dpdu, &hitPoint->dpdu.x);
<kernel>:14915:18: warning: passing 'const __global float *' to parameter of type '__global float *' discards qualifiers
VSTORE3F(dpdv, &hitPoint->dpdv.x);
<kernel>:17195:63: error: passing 'const __attribute__((address_space(16776963))) float3' to parameter of incompatible type 'const __global BSDF *'
const float3 result = SphereLight_Illuminate(mapSphereLight, p, u0, u1,
<kernel>:17098:24: note: passing argument to parameter 'bsdf' here
__global const BSDF *bsdf, const float u0, const float u1,
EDIT (Latest build)
Console report:
[LuxRays][27.171] [Device GeForce GTX 1070 Intersect] Pixel Filter Distribution buffer size: 33Kbytes
[LuxCore][27.171] [PathOCLBaseRenderThread::0] Defined symbols: -D LUXRAYS_OPENCL_KERNEL -D SLG_OPENCL_KERNEL -D RENDER_ENGINE_RTPATHOCL -D PARAM_RAY_EPSILON_MIN=1.000000e-05f -D PARAM_RAY_EPSILON_MAX=1.000000e-01f -D PARAM_LIGHT_WORLD_RADIUS_SCALE=1.050000e+00f -D PARAM_ACCEL_MBVH -D PARAM_FILM_RADIANCE_GROUP_0 -D PARAM_FILM_RADIANCE_GROUP_1 -D PARAM_FILM_RADIANCE_GROUP_COUNT=2 -D PARAM_ENABLE_TEX_CONST_FLOAT -D PARAM_ENABLE_TEX_CONST_FLOAT3 -D PARAM_ENABLE_TEX_IMAGEMAP -D PARAM_ENABLE_TEX_NORMALMAP -D PARAM_ENABLE_TEX_FRESNELCOLOR -D PARAM_ENABLE_TEX_FRESNELCONST -D PARAM_ENABLE_MAT_MATTE -D PARAM_ENABLE_MAT_ROUGHMATTE -D PARAM_ENABLE_MAT_MIRROR -D PARAM_ENABLE_MAT_GLASS -D PARAM_ENABLE_MAT_ARCHGLASS -D PARAM_ENABLE_MAT_NULL -D PARAM_ENABLE_MAT_MATTETRANSLUCENT -D PARAM_ENABLE_MAT_ROUGHMATTETRANSLUCENT -D PARAM_ENABLE_MAT_GLOSSY2 -D PARAM_ENABLE_MAT_GLOSSY2_ABSORPTION -D PARAM_ENABLE_MAT_GLOSSY2_INDEX -D PARAM_ENABLE_MAT_GLOSSY2_MULTIBOUNCE -D PARAM_ENABLE_MAT_METAL2 -D PARAM_ENABLE_MAT_ROUGHGLASS -D PARAM_ENABLE_MAT_CLEAR_VOL -D PARAM_ENABLE_MAT_HOMOGENEOUS_VOL -D PARAM_ENABLE_MAT_GLOSSYTRANSLUCENT -D PARAM_HAS_PASSTHROUGH -D PARAM_CAMERA_TYPE=0 -D PARAM_HAS_INFINITELIGHT -D PARAM_HAS_CONSTANTINFINITELIGHT -D PARAM_HAS_SKYLIGHT2 -D PARAM_HAS_SUNLIGHT -D PARAM_HAS_SHARPDISTANTLIGHT -D PARAM_HAS_DISTANTLIGHT -D PARAM_HAS_POINTLIGHT -D PARAM_HAS_MAPPOINTLIGHT -D PARAM_HAS_SPOTLIGHT -D PARAM_HAS_PROJECTIONLIGHT -D PARAM_HAS_LASERLIGHT -D PARAM_HAS_TRIANGLELIGHT -D PARAM_HAS_SPHERELIGHT -D PARAM_HAS_MAPSPHERELIGHT -D PARAM_HAS_ENVLIGHTS -D PARAM_HAS_IMAGEMAPS -D PARAM_IMAGEMAPS_PAGE_0 -D PARAM_IMAGEMAPS_COUNT=1 -D PARAM_HAS_IMAGEMAPS_BYTE_FORMAT -D PARAM_HAS_IMAGEMAPS_HALF_FORMAT -D PARAM_HAS_IMAGEMAPS_FLOAT_FORMAT -D PARAM_HAS_IMAGEMAPS_1xCHANNELS -D PARAM_HAS_IMAGEMAPS_3xCHANNELS -D PARAM_HAS_IMAGEMAPS_WRAP_REPEAT -D PARAM_HAS_BUMPMAPS -D PARAM_HAS_VOLUMES -D SCENE_DEFAULT_VOLUME_INDEX=4294967295 -D PARAM_MAX_PATH_DEPTH=9 -D PARAM_MAX_PATH_DEPTH_DIFFUSE=6 -D PARAM_MAX_PATH_DEPTH_GLOSSY=7 -D PARAM_MAX_PATH_DEPTH_SPECULAR=7 -D PARAM_RR_DEPTH=3 -D PARAM_RR_CAP=5.000000e-01f -D PARAM_SQRT_VARIANCE_CLAMP_MAX_VALUE=1.000000e+05f -D PARAM_IMAGE_FILTER_TYPE=2 -D PARAM_IMAGE_FILTER_WIDTH_X=1.500000e+00f -D PARAM_IMAGE_FILTER_WIDTH_Y=1.500000e+00f -D PARAM_IMAGE_FILTER_PIXEL_WIDTH_X=1 -D PARAM_IMAGE_FILTER_PIXEL_WIDTH_Y=1 -D PARAM_IMAGE_FILTER_GAUSSIAN_ALPHA=2.000000e+00f -D PARAM_USE_PIXEL_ATOMICS -D PARAM_HYBRID_BACKFORWARD -D PARAM_HYBRID_BACKFORWARD_GLOSSINESSTHRESHOLD=1.000000e-01f -D PARAM_SAMPLER_TYPE=3 -D PARAM_ELVC_GLOSSINESSTHRESHOLD=0.0f -D PARAM_RTPATHOCL_PREVIEW_RESOLUTION_REDUCTION=4 -D PARAM_RTPATHOCL_PREVIEW_RESOLUTION_REDUCTION_STEP=8 -D PARAM_RTPATHOCL_RESOLUTION_REDUCTION=1 -D LUXCORE_NVIDIA_OPENCL
[LuxCore][27.171] [PathOCLBaseRenderThread::0] Compiling kernels
[LuxCore][27.328] [PathOCLBaseRenderThread::0] PathOCL kernel compilation error
Posted: Mon Jul 22, 2019 1:57 pm
kintuX wrote: Mon Jul 22, 2019 1:35 pm
EDIT (Latest build)
Console report:
I should have now fixed this too.
Posted: Mon Jul 22, 2019 2:10 pm
Dade wrote: Mon Jul 22, 2019 1:57 pm
EDIT (Latest build)
Console report:
Yes, it works now
man, you're the greatest!
Posted: Mon Jul 22, 2019 10:02 pm
by johannes.wilde
Thank you, man!
It works, even the viewport denoising works now.
