Page 2 of 2
Re: Volume bug at opacity = 0?
Posted: Thu Jul 11, 2019 6:53 pm
Dade wrote: Thu Jul 11, 2019 6:27 pm
Transparency makes both the surface and the volume not visible: the object is not hit at all. If a ray doesn't hit the surface, it will never enter the interior volume (and then exit).
I understand what you explain but the question remains: Why is the volume visible if camera volume node is removed (volume = - -)?
You should try to mix Disney wit Null, it should work
Okay. This sounds logical. According to my experience this works. To be 100% sure I am going to check it.
Posted: Thu Jul 11, 2019 8:36 pm
FarbigeWelt wrote: Thu Jul 11, 2019 6:53 pm
I will try to answer when I'm back in town, I'm with a tablet and a mobile connection at the moment.
Posted: Fri Jul 12, 2019 5:50 am
I tried and it worked as expected. With the mix Disney BRDF-Null and opacity adjustment of Disney BRDF you can get an image as follows.
- BDRF-Null mix, 500 samples OIDN 0.9
Because the corner in the back is rather dark 500 even 1500 samples are not enough to render the fine rectangles pattern.
Maybe Env. cache can improve quality here.
- BDRF-Null mix,1500 samples OIDN 0.9
