Re: Convert World Sky Texture and Sun to Cycles
Posted: Thu May 16, 2019 4:43 pm
Settings are the same. Color is Filmic base contrast. Lux produces different world and sun lights.
Settings are the same. Color is Filmic base contrast. Lux produces different world and sun lights.Sharlybg wrote: Thu May 16, 2019 4:21 pmLook like tonemapping isn't the sameMaxNadolny wrote: Thu May 16, 2019 3:42 pm The second image is Cycles. Personally I prefer Lux render result.![]()
Thank you very much for your opinion.CodeHD wrote: Thu May 16, 2019 4:40 pm I like the Lux result a bit better
pro-lux:
- the stacks of plates have stronger shadows in between (not necessarily more correct, but looks nicer), and it looks a bit overexposed on the top, which I would expect from a photo in this situation. The cycles plates are very "milky", like when you reduce highlights in a raw converter.
- I like the color of the bottles better
- The fume hood look more like metal. Cycles is too flat. (concerns the other metals parts, too, though too a lesser degree)
- I like the floor a bit better. Unnaturally glossy in cycles for wood (?)
pro-cycles:
- Some of the pots stored under the table are more glossy, which I like for the same reason as the fume hood in lux.
-pro-neither:
- The reflection seen on the pots is very different. I wonder why that is? You definitley made changes between the images, I can see some of the cupboard-door-knobs moving![]()
- In both cases, maybe some texturing is missing. You know, giving everything those slight imperfections like scratches or a speck of dirt. I like, for example, that you didn't stack the plates perfectly![]()
