Page 2 of 4
Re: Interior & exterior gghouse
Posted: Tue Apr 23, 2019 9:13 am
by Peperepe77
Thank's Dade for explanation!
This scene has a longer "session init time" 15 mins, is it a time to calculate grass particle system? Session init time is to calculate photonGI ?
Posted: Tue Apr 23, 2019 9:24 am
Peperepe77 wrote: Tue Apr 23, 2019 9:13 am
I think so even if for a real answer I should see the logs. It is a very long pre-processing time. The latest build has also an automatic optimal radius selection and stop conditions: you parameters are probably over the top and case a very long preprocessing.
If you can upload your scene (just the empty room with only walls, windows and background), we can check the settings and look for what could be optimal.
Posted: Tue Apr 23, 2019 9:28 am
I would disable the Direct Light Sampling Cache (DLSC), it's probably responsible for the long session init time.
The PhotonGI settings look like it is computed very fast. Halt threshold of 57% in PhotonGI is probably even too low quality (preview quality is 15%, final quality is 5%).
Posted: Tue Apr 23, 2019 9:43 am
by Peperepe77
I tried to turn-off particle system, init session is 2 mins.
I try your suggestion BYOB.
Thank's a lot guys
Posted: Tue Apr 23, 2019 10:06 am
Particle system conversion is part of the "export time" in the statistics table.
Posted: Sun May 05, 2019 1:31 pm
by Peperepe77
A new view for this project.
Posted: Tue May 14, 2019 2:40 pm
by Peperepe77
Hi guys, this is an update for exterior scene. I need help to create a good water material for the pool; now is a simple plane with glass material IOR 1,333.I should to add interior or exterior volume? There is a lux tutorial? Here references
https://www.archdaily.com/907558/gg-house-sommet
Posted: Thu May 16, 2019 2:31 pm
by Piita
Yes you should add an interior volume for the water. Click the Add button on the material output node and you should now have a clear volume node added for you. Put a slight blue color as absorption color.
The water in your render looks dark. Make sure that transmission and reflection color is full white on the glass node.
Posted: Fri May 17, 2019 10:05 am
by Peperepe77
Thank's Piita, very useful. This setup need a real water mesh? I should model water such as box/volume of interior pool, is it correct?
Now water is a simple plane with glass material, I turn on "architectural" , it results more transparent but a fake water material
I try with volume.
Posted: Fri May 17, 2019 12:32 pm
As long as the camera stays above the water surface, a plane is enough.
Peperepe77 wrote: Fri May 17, 2019 10:05 am
Unidirectional pathtracing can't render light refracted on the floor below the water efficiently, because it's technically caustics.
"Architectural" glass means that refractions are ignored and the render engine can do direct light sampling through the water, this is fine if the water surface has no waves, but will look fake if the surface has bump/displacement.
For correct rendering of the caustics, you will have to use Bidir + Metropolis.
An interior volume can be used to get correct absorption, and will work fine in all engines.
