Re: OpenCL/C++ hybrid rendering
Posted: Thu Feb 15, 2018 1:48 pm
niiice indeed
& here's a thought that is lately occupying my mind...
Could it be possible to manage units/devices so that they render per frame (for example as Farms work)?
For now it's possible to do it manually as one-by-one (1scene : 1blender app) rendering - at the same time:
1.frame/CPU1 + 2.frame/GPU1 + 3.frame/GPU2 + ...
One could even go further splitting rendering work (frames) for CPU by core (but haven't tried this yet
The advantage is mostly prominent with animations of advanced (more complex) scenes:
+ more secure - if something goes wrong, not everything is wrong (unless the whole system collapses)
+ better time/resource prediction
+ less computing time per frame (compiling only for one unit/frame)
+ still enough computing resources available (at least one core) to continue working on other areas (post, composite, tonne mapping, checking, debugging, communications...)
+ after getting used to it, workflow/thought flow gets faster into the zone (less interrupted)
Have already done this, but manually & only with Cycles. On a single machine - otherwise i would need to have 3.
As time was of the essence, this workflow made it possible for me to deliver on time & some extra.
