Try to build windows from source with the latest source and I face this issue, I can download and add the Odin Files but I assume it should be automatically downloaded by the build script so I post it to be sure.
CMake Error at CMakeLists.txt:126 (MESSAGE):
--> Could not locate required Intel Oidn files - Please check
Re: Could not locate required Intel Oidn files
It's working flawlessly here:
-- Intel OIDN support: enabled
Compilazione completata.
Avvisi: 0
Errori: 0
Tempo trascorso 00:10:52.96
Deps are automatically downloaded by the build script only if a "WindowsCompileDeps" directory is not found, otherwise the existing is used.
maybe I'm on the wrong repo or I should do a clean build, I will delete all the Deps and try one more time to see if it will solve the issue for me and I will get back to you.acasta69 wrote: ↑Tue Mar 01, 2022 8:10 pmIt's working flawlessly here:
Are you sure you are using the latest version of WindowsCompileDeps?Code: Select all
... ... -- Intel OIDN support: enabled ... ... Compilazione completata. Avvisi: 0 Errori: 0 Tempo trascorso 00:10:52.96
Sorry, it was my mistake WindowsCompile was on the wrong branch called "oiio_renamed" after I merged the master repo everything was fine and the source compiled with no Deps issue.
