How to speedup instances operations?
Re: How to speedup instances operations?
Hi "Dade", if this is a correct approach please give me access to the repo so I can update it and also add more features. Thank you. if I need to improve it I will be more than happy to give me a few suggestions.
You can fill a "Pull Request", anyone can: https://docs.github.com/en/pull-request ... ll-request
Wow! That's great! This was the last issue which forced our users to reinitialize the real time session. Thanks a lot!
Thank you dade, a will create a pull request, just one question. should I work on new code and test it with the master branch always? and do you have any suggestions about the code?Dade wrote: Fri Feb 25, 2022 9:11 pm You can fill a "Pull Request", anyone can: https://docs.github.com/en/pull-request ... ll-request
Yes, the master branch is always the "next" main version, maintenance/minor versions, if they existing, are on a separate branches.TAO wrote: Sat Feb 26, 2022 7:47 amThank you dade, a will create a pull request, just one question. should I work on new code and test it with the master branch always? and do you have any suggestions about the code?Dade wrote: Fri Feb 25, 2022 9:11 pm You can fill a "Pull Request", anyone can: https://docs.github.com/en/pull-request ... ll-request
bartek_zgo
Thanks TAO for your code.
Unfortunately I'm not able to compile. I cloned repository and started from 0. Start command firt_run and than build-64-sse2 LuxCore-sdk 5
Everything was perfect. No compile errors.
So I made changes in scene.cpp and scene.h. Run again build-64-sse2 LuxCore 5. No compile errors.
So I made changes in luxcore.h. And I got following error:
/mnt/nodeHDD1/LuxCore/LuxCore_latest/LinuxCompile/LuxCore-sdk/src/luxcore/luxcoreimpl.cpp: In constructor ‘luxcore::detail::RenderConfigImpl::RenderConfigImpl(const luxrays::Properties&, luxcore::detail::SceneImpl*)’:
/mnt/nodeHDD1/LuxCore/LuxCore_latest/LinuxCompile/LuxCore-sdk/src/luxcore/luxcoreimpl.cpp:1225:44: error: invalid new-expression of abstract class type ‘luxcore::detail::SceneImpl’
scene = new SceneImpl(renderConfig->scene);
In file included from /mnt/nodeHDD1/LuxCore/LuxCore_latest/LinuxCompile/LuxCore-sdk/src/luxcore/luxcoreimpl.cpp:39:
/mnt/nodeHDD1/LuxCore/LuxCore_latest/LinuxCompile/LuxCore-sdk/include/luxcore/luxcoreimpl.h:145:7: note: because the following virtual functions are pure within ‘luxcore::detail::SceneImpl’:
class SceneImpl : public Scene {
In file included from /mnt/nodeHDD1/LuxCore/LuxCore_latest/LinuxCompile/LuxCore-sdk/src/luxcore/luxcoreimpl.cpp:38:
/mnt/nodeHDD1/LuxCore/LuxCore_latest/LinuxCompile/LuxCore-sdk/include/luxcore/luxcore.h:1094:15: note: ‘virtual void luxcore::Scene::DeleteObjects(std::vector<std::__cxx11::basic_string<char> >&)’
virtual void DeleteObjects(std::vector<std::string> &objNames) = 0;
/mnt/nodeHDD1/LuxCore/LuxCore_latest/LinuxCompile/LuxCore-sdk/include/luxcore/luxcore.h:1101:15: note: ‘virtual void luxcore::Scene::DeleteObjectsInstance(const string&, unsigned int, unsigned int)’
virtual void DeleteObjectsInstance(const std::string &prefixName, const unsigned int count, const unsigned int start) = 0;
you need to add it in luxcoreimpl .
in luxcoreimpl.h around the line 206 add delete function deceleration, it should look like this:
in luxcoreimpl.cpp around the line 1060 add functions as before you can add scenePropertiesCache.Clear(); in it too. it should look like this:
avoid repeating the existing functions. I add the deleting multiple lights too if you do not need it to remove it or use the next message to add it to the source.
it should compile with no issue.
void DeleteObject(const std::string &objName);
void DeleteObjects(std::vector<std::string> &objNames);
void DeleteObjectsInstance(const std::string &prefixName, const unsigned int count, const unsigned int start);
void DeleteLight(const std::string &lightName);
void DeleteLights(std::vector<std::string> &lightNames);
void SceneImpl::DeleteObject(const string &objName) {
API_BEGIN("{}", ToArgString(objName));
// Invalidate the scene properties cache
scene->DeleteObject(objName);
API_END();
void SceneImpl::DeleteObjects(std::vector<std::string> &objNames) {
BOOST_FOREACH(const string &objName, objNames) {
void SceneImpl::DeleteObjectsInstance(const std::string &prefixName, const unsigned int count, const unsigned int start) {
// Deleting the instances from the start amount till the counting number of instances
for (unsigned int i = 0; i < start + count; i++)
string objectName = prefixName + std::to_string(i);
scene->DeleteObject(objectName);
void SceneImpl::DeleteLight(const string &lightName) {
API_BEGIN("{}", ToArgString(lightName));
scene->DeleteLight(lightName);
API_END();
void SceneImpl::DeleteLights(std::vector<std::string> &lightNames) {
// Separate the objects and send them to delete
BOOST_FOREACH(const string &lightName, lightNames) {
in the last scene, i added deleting multiple lights too, so you need to remove it or added it as blew to other parts of the code.
in scene.h line 161 after DeleteLight deceleration add:
in luxcore.h line 1103 after DeleteLight deceleration add:
and finally in scene.cpp line 526 after DeleteLight deceleration add:
* \brief Deletes multiple lights from the scene.
* \param lightNames is the vector array name of the object to delete. Note: to delete
* area lights, use DeleteObject().
virtual void DeleteLights(std::vector<std::string> &lightNames) = 0;
void Scene::DeleteLights(std::vector<std::string> &lightNames) {
bartek_zgo
Hi. I have compiled the code. It is working but there is no time improvement.
I have analyzed the code and in my opinion the problem is in NamedObjectVector::DeleteObj(const std::string &name);
This code is dramatically slow. You should add DeleteObj(objectNamesArray) or something like that.
Take a look at this code. First you search index by name: GetIndex(name); (just this is not a happy solution when repeated many times).
But after this, you rebuild some index array! So it is done, each time you remove an instance. So if I remove 1000 instances, you rebuild the index array 1000 times!
First quite easy fix would be to pass a vector of instances names to remove, and rebuild indexes only once after removing all instances!
This is an easy way, that should speed up. But to do it well, it should be done in more complex way, that I'm not sure is it possible or not, because I don't know the code very well.
We want to remove some range of instances based on index. So I think GetIndex(name) could be called only once. As I suppose next instance should just have next index. I hope that if for example instance "petal_74" has index 138, "petal_75" has index 139. I hope so, but I don't know the data structure.
i will check the code to see if there is any way to make the delete function faster as well.bartek_zgo wrote: Wed Mar 02, 2022 9:14 am Hi. I have compiled the code. It is working but there is no time improvement.
in mean while the function corresponding to delete objects is in namedobjectvectore.cpp
void NamedObjectVector::DeleteObj(const std::string &name) {
const u_int index = GetIndex(name);
objs.erase(objs.begin() + index);
// I have to rebuild the indices from scratch
name2index.clear();
index2obj.clear();
for (u_int i = 0; i < objs.size(); ++i) {
NamedObject *obj = objs[i];
name2index.insert(Name2IndexType::value_type(obj->GetName(), i));
index2obj.insert(Index2ObjType::value_type(i, obj));
