Thank you I'll check it tonight.Ericka wrote: Sat Apr 10, 2021 6:06 pm I see a few issues that i reported in Github.
First, Power, Divide, subtract, less and greaterthan maps slots are gray and can not be assigned to any kind of maps.
https://github.com/LuxCoreRender/MaxToLux/issues/64
Second, Changing maps on map/material slots not showing instantly and need refreshing the parameters.
https://github.com/LuxCoreRender/MaxToLux/issues/65
I double checked the UV settings and that's the result:
@Patro, Is that what you report for fliped images with correct UV?
If this is the correct result you expect let me know.
TAO, do you refer to thisTAO wrote: Mon Apr 12, 2021 7:40 pm I double checked the UV settings and that's the result:
from the image you posted, it looks like the bitmap on the luxball is rendered correctly, Looking on your photo and on the rendered luxball, your wife is on your left.When using a bitmap map to texture a material, the used bitmap is rendered mirrored if the geometry has no UVW Map modifier applied.
My wife is on the right side that's me on the left side. I should use a better quality image.patro wrote: Mon Apr 12, 2021 8:59 pmTAO, do you refer to thisTAO wrote: Mon Apr 12, 2021 7:40 pm I double checked the UV settings and that's the result:
If this is the correct result you expect let me know.from the image you posted, it looks like the bitmap on the luxball is rendered correctly, Looking on your photo and on the rendered luxball, your wife is on your left.When using a bitmap map to texture a material, the used bitmap is rendered mirrored if the geometry has no UVW Map modifier applied.
no need for a better bitmap, it is clearly working correctly now, and of course without uvw map modifier.TAO wrote: Mon Apr 12, 2021 11:37 pmMy wife is on the right side that's me on the left side. I should use a better quality image.patro wrote: Mon Apr 12, 2021 8:59 pmTAO, do you refer to thisTAO wrote: Mon Apr 12, 2021 7:40 pm I double checked the UV settings and that's the result:
If the output of the bitmap would be flipped in the rendered image you would be shown on the right and your wife on the left.
I've posted a feature request on github
I hope someone has some insight to share about or better ideas.
Comments are welcome
one user report a crash with 3dsmax 2020, did you see anything like that, node based material editor + standard material?
Well I had that before, but your last 2 builds fixed already that crashing.TAO wrote: Tue Apr 13, 2021 2:13 pmone user report a crash with 3dsmax 2020, did you see anything like that, node based material editor + standard material?
I think next MaxtoLux will render it even better
It is just a test for the lighting.
1000x1000 600 samples, denoiser, 16 minutes rendering on my laptop I think it's impressive
Wow, you're getting good. that's impressive piece of work.patro wrote: Tue Apr 13, 2021 4:16 pm I think next MaxtoLux will render it even better![]()
