patro
Post by patro »
Hi TAO, the cut edge is gone. To do so there is a setting to flag. see attachment
But the strange deformation of the reflected lights and metric grid is not all gone, right near the cutted holes you will notice a deviation of the grid lines from its natural path. Strange that it doesn't happen with vray.
I think the luxCore behavior is normal but I don't know why is not happening with Vray.
I need to check that, maybe, they are welding close vertexes on the translation process.
better support of bump map on GPU.
There is an issue that still remains that any color map texture will affect defuse color but I'm working on it.
patro
Post by patro »
Hi TAO, when will you release the next build?
patro wrote: Sat Jan 23, 2021 2:59 pm Hi TAO, when will you release the next build?
As soon as I implement the code for multi-sub material or material-ID.
It should not take longer than 1 week.
As Dade mention, 3dsmax scenes are way big compare to what we see in almost all other software, so I add a method to match 3dsmax scenes in the metric systems to other software like blender.
It works for LuxCore too and has a huge impact on the render results.
The Old scene with no scale match.
The new one in the metric system with scene match.
now every scene should be scale as LuxCore expected.
In addition, I add two parameters for the usual scene that does not in the metric system unit.
scene.epsilon.min = 0.01
scene.epsilon.max = 0.1
it's a bit different from the scale size match but work perfectly with adding a little bit of extra time to render.
patro
Post by patro »
TAO wrote: Mon Jan 25, 2021 10:17 am It works for LuxCore too and has a huge impact on the render results.
Hi, just to get you right, does this also makes rendering 3ds max user faster as we are used now with LuxCore?
by the way, is it possible to ad rendertime to maxtolux? would be nice add to know, how long it takes to render a given scene
patro wrote: Mon Jan 25, 2021 10:37 am
you mean like a stamp to write text on image?
patro
Post by patro »
TAO wrote: Mon Jan 25, 2021 12:42 pm
yes, or maybe as renderers does in 3ds max, in the lower left corner of the 3ds max UI, this information is available after rendering end.
Vray does deliver this information too in the same way,
patro wrote: Mon Jan 25, 2021 2:32 pm
Good idea, I'll try to add it in the next build.
you can add a feature request to the GitHub repository too.
That makes it easier to keep tracking of features and bugs.
