Page 1 of 4
LuxCoreRender v2.2alpha0 released
Posted: Mon Feb 25, 2019 4:34 pm
v2.2 alpha0 released
New LuxCoreRender v2.2alpha0 release is available.
v2.2 release notes are available here:
https://wiki.luxcorerender.org/LuxCoreR ... Notes_v2.2
This is the first v2.2 release and includes a couple of major new features: PhotonGI cache and Intel Open Image Denoise Library (including Blender viewport pre-view).
PhotonGI cache
Indirect and caustic cache can easily improve the rendering time of some scene of a 5-10 factor. It is really a game changing tool, especially for ArchiViz interior renderings.
Oidn is another new major feature capable to significantly reduce rendering times, both of pre-views and final renderings.
LuxCoreRender v2.2alpha0 files
BlendLuxCore is available here:
https://github.com/LuxCoreRender/BlendL ... v2.2alpha0
Standalone LuxCoreRender is available here:
https://github.com/LuxCoreRender/LuxCor ... v2.2alpha0
VisualStudio 2017 builds
NOTE: this release for Windows is compiled with VisualStudio 2017. You may need to install the VS2017 runtime libraries: https://support.microsoft.com/en-us/hel ... -downloads
Re: LuxCoreRender v2.2alpha0 released
Posted: Mon Feb 25, 2019 4:51 pm
How to use the new Intel denoiser:
For final renders:
Open the render properties and enable the "LuxCore Denoiser" panel. The intel denoiser (OIDN) is selected by default.
Start the render and open the tool panel (shortcut T), then select the "LuxCore" category on the left.
You can run the denoiser at any time during the rendering. To see the denoised result, switch the pass from "Combined" to "DENOISED".
For viewport renders:
The denoiser is enabled by default for viewport renders, you don't have to do anything to use it. Just let the viewport render run until it pauses and the denoiser will kick in. You can change when the viewport pauses in the render properties, "LuxCore Viewport Settings" panel. You can also disable the viewport denoising in this panel.
Note: The viewport denoiser currently does not work in the following cases:
- Transparent film enabled in camera settings
- Imagepipeline plugins that distort the image might throw off the denoiser, for example color aberration or bloom (this does not affect final renders)
Videos of the viewport denoiser:
https://youtu.be/_-6eCi4VX3o
https://youtu.be/cABKkp1JOl0
Posted: Mon Feb 25, 2019 5:07 pm
How to use the new PhotonGI cache:
Open the render properties and enable the "LuxCore PhotonGI Cache" panel.
By default, only the indirect cache is enabled while the caustic cache is disabled.
Parameters
The parameters are a work in progress and not yet finished, in the future some of them will be automated or hidden.
The ones you need to change most often are the photon count (use more photons if the cache is splotchy) and the lookup radius (scale it with your scene, the default of 15 cm is suitable for a room-sized interior scene).
In scenes with hidden light sources that require many bounces you might need to increase the photon depth.
Most parameters should have tooltips with further explanations.
Note that the photon count and max. size parameters are in thousands, so if you enter "100", 100000 photons are fired/stored.
The three advanced parameters normal angle, usage threshold scale and glossiness threshold should be left at their defaults in most cases.
You can use the debug setting to view a cache directly, to make it easier to judge the cache quality.
Posted: Mon Feb 25, 2019 7:07 pm
by wasd
Doesn't work for me.
I installed VS2017 runtime libraries.
Posted: Mon Feb 25, 2019 7:19 pm
wasd wrote: ↑Mon Feb 25, 2019 7:07 pm
Did you restarted Blender after the upgrade ?
Posted: Mon Feb 25, 2019 7:22 pm
Looks successful to me. Have you restarted Blender?
Posted: Mon Feb 25, 2019 7:29 pm
by wasd
Yep,
Dade wrote: ↑Mon Feb 25, 2019 7:19 pm
B.Y.O.B. wrote: ↑Mon Feb 25, 2019 7:22 pm
Yep, it seems it works, but reports wrong version, so I tried to upgrade once more, got that error and thought it doesn't work.
Posted: Mon Feb 25, 2019 7:45 pm
I'm creating a Blenderartists Thread for 2.2
Posted: Mon Feb 25, 2019 7:51 pm
wasd wrote: ↑Mon Feb 25, 2019 7:29 pm
Ah, I forgot to update the version number.
I found two other issues, once they are fixed, I'll repackage v2.2alpha0.
Posted: Mon Feb 25, 2019 8:06 pm
On Linux, you have to update to v2.2alpha0 manually if you want to use the viewport denoiser, because the OIDN executable made a change in the updater necessary (the "denoise" binary needs to be executable, you can also fix this manually with "chmod +x denoise").
