Page 1 of 2
Network Render
Posted: Fri Feb 14, 2020 10:14 pm
by mib2berlin
Hi, I would like to test network render and got error installing PySide with:
sudo pip3 install --install-option="--jobs=4" PySide
ERROR: Command errored out with exit status 1:
     command: /usr/bin/python3 -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-nw01ambb/PySide/setup.py'"'"'; __file__='"'"'/tmp/pip-install-nw01ambb/PySide/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-install-nw01ambb/PySide/pip-egg-info
         cwd: /tmp/pip-install-nw01ambb/PySide/
    Complete output (1 lines):
    only these python versions are supported: [(2, 6), (2, 7), (3, 2), (3, 3), (3, 4)]
ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
I have Python 2.7 and 3.7 installed and System PySide does not do anything, it seams.
Tested with LuxCore 2.2 and latest Git build.
Would be very grateful for help.
Cheers, mib
EDIT: It seams forum search is broken
Re: Network Render
Posted: Sat Feb 15, 2020 12:53 am
by Fox
I don't know if i did right, but this is what i did in Linux:
sudo apt-get install libpython3-all-dev
sudo apt-get install python3-pip
sudo pip3 install pyinstaller
sudo pip3 install PySide2
sudo apt-get install python3-numpy
Re: Network Render
Posted: Sat Feb 15, 2020 1:38 am
by mib2berlin
Thanks, sudo pip3 install pyinstaller solve the error but ...
Got another. :)
Network render button does nothing and I read in Wiki you have to manually start netrender on some distros.
I am on Opensuse so I try python pyluxcoretools.zip and got:
  File "/usr/lib64/python2.7/runpy.py", line 174, in _run_module_as_main
    "__main__", fname, loader, pkg_name)
  File "/usr/lib64/python2.7/runpy.py", line 72, in _run_code
    exec code in run_globals
  File "pyluxcoretools.zip/__main__.py", line 40, in <module>
  File "pyluxcoretools.zip/pyluxcoretools/pyluxcoreconsole/cmd.py", line 26, in <module>
    The `default' method may be overridden to intercept commands for which there
ImportError: ./pyluxcore.so: undefined symbol: PyUnicode_AsUTF8String
I google a bit and it seams to be a Python path problem.
is it may be because I have Python 2.7 and 3.7 installed?
Cheers, mib
Re: Network Render
Posted: Sat Feb 15, 2020 7:40 am
by acasta69
Not sure about that error, but I think that pyluxcore needs python 3.x.
Normally there should be a 'python3' command on Linux to run python 3. Have you tried that?
python3 pyluxcoretools.zip
I don't know about differences between various Linux versions, though...
Re: Network Render
Posted: Sat Feb 15, 2020 10:15 am
by mib2berlin
Hi and thank you, with python3 application start but crash with:
Speicherzugriffsfehler (Speicherabzug geschrieben)
Meant Memory access error.
It would be nice if a Linux user can test the netrender function in Blender or from command shell to verify it is working but not on my system.
Cheers, mib
CPU i7-3520M 8 GB
GPU Intel HD4000
xf86-video-intel 2.99.917-6.1
KDE Plasma 5.59.0-1.1
Vivaldi 2.11.1811.28 (Official Build) snapshot (64-bit)
LuxCore 2.2 without OpenCL
EDIT: I will check on workstation with Nvidia card, too.
Re: Network Render
Posted: Sat Feb 15, 2020 10:33 am
by mib2berlin
Hi, it work on my workstation.
I have to double check if I really use the NoOpenCL version on my laptop.
Many thanks for the help, mib
EDIT: OK, 2.3 beta does not work on my Windows render node, 2.2 is working.
Give up for now.
Re: Network Render
Posted: Mon Feb 17, 2020 4:27 pm
by acasta69
Give up for now.
could you please post the error message you get on Windows?
For example, I get:
C:\Dati\Various\Personal\Devel\luxcorerender\WindowsCompile\luxcorerender>python pyluxcoretools.zip netnodeui
  File "C:\Program Files\Python37\lib\runpy.py", line 193, in _run_module_as_main
    "__main__", mod_spec)
  File "C:\Program Files\Python37\lib\runpy.py", line 85, in _run_code
    exec(code, run_globals)
  File "pyluxcoretools.zip\__main__.py", line 71, in <module>
  File "pyluxcoretools.zip\pyluxcoretools\pyluxcorenetnode\ui.py", line 144, in main
  File "pyluxcoretools.zip\pyluxcoretools\pyluxcorenetnode\ui.py", line 135, in ui
  File "pyluxcoretools.zip\pyluxcoretools\pyluxcorenetnode\ui.py", line 46, in __init__
  File "pyluxcoretools.zip\pyluxcoretools\pyluxcorenetnode\mainwindow.py", line 196, in setupUi
AttributeError: 'PySide2.QtWidgets.QAction' object has no attribute 'activated'
It might be a bug in PySide2 5.14, I'm checking.
By the way, it could be the same thing producing what described in this post.
Re: Network Render
Posted: Tue Feb 18, 2020 12:51 am
by mib2berlin
Hi, I will check tomorrow and post error message and have a closer look to the other thread.
Thank you, mib
EDIT: Got not exactly the same errors:
C:\Users\pepo\Downloads\blender-2.82-windows64\2.82\scripts\addons\BlendLuxCore\bin>python pyluxcoretools.zip netnodeui
ImportError: numpy.core.multiarray failed to import
ImportError: numpy.core.umath failed to import
  File "C:\Users\pepo\AppData\Local\Programs\Python\Python37\lib\runpy.py", line 193, in _run_module_as_main
  File "C:\Users\pepo\AppData\Local\Programs\Python\Python37\lib\runpy.py", line 85, in _run_code
Re: Network Render
Posted: Tue Feb 18, 2020 10:14 am
It looks like this problem: https://stackoverflow.com/questions/455 ... te-qwidget
The error is in a .py generated from a .ui file (so there must be a problem in pyside2-uic tool).
Does Azure regenerate the .py file starting from .ui files ? There may be also a problem if both PySide1 and PySide2 are installed at the same time: https://github.com/LuxCoreRender/LuxCor ... ts.txt#L37 (PySide1 is used).
Re: Network Render
Posted: Tue Feb 18, 2020 12:26 pm
by acasta69
Yes, indeed the code generated by pyside2-uic is different starting from version 5.14.
This is the code from version 5.13.2 (and pre-generated files):
        self.retranslateUi(MainWindow)
        QtCore.QObject.connect(self.actionQuit, QtCore.SIGNAL("activated()"), MainWindow.clickedQuit)
        QtCore.QObject.connect(self.pushButtonResetConfiguration, QtCore.SIGNAL("clicked()"), MainWindow.clickedResetConfig)
        QtCore.QObject.connect(self.pushButtonStartNode, QtCore.SIGNAL("clicked()"), MainWindow.clickedStartNode)
        QtCore.QObject.connect(self.pushButtonStopNode, QtCore.SIGNAL("clicked(bool)"), MainWindow.clickedStopNode)
        QtCore.QMetaObject.connectSlotsByName(MainWindow)
Instead this is generated with version 5.14 and newer:
        self.actionQuit.activated.connect(MainWindow.clickedQuit)
        self.pushButtonResetConfiguration.clicked.connect(MainWindow.clickedResetConfig)
        self.pushButtonStartNode.clicked.connect(MainWindow.clickedStartNode)
        self.pushButtonStopNode.clicked.connect(MainWindow.clickedStopNode)
Do you know if this is working correctly on Linux with PySide 2 5.14.x?
On Windows I think I will revert to PySide2 5.13.2 until I have investigated this a bit better.
On Windows the .py files are always regenerated from the ui files, even when PySide2 is installed.
IIRC, time ago I found there is some slight difference between Linux and Windows in how CMake executes the related custom commands. I was not able to prevent regeneration on Windows and then gave up since it's a very fast operation anyway.
About having PySide 1 and 2 at the same time... I didn't consider that, I hope it's rare enough...
By the way, PySide1 has not been maintained for long time now: do you think we should continue to support it?
