Page 2 of 4
Re: Material/Texture rework in v2.3
Posted: Thu May 02, 2019 4:51 pm
by CodeHD
if we are talking about properties read from file, i would add BRDF/BSDF-data from a file to get realistic (also anisotropic) matte/glossy mixtures. Although I believe that not many people will even have such data available, so it will be a corner case...
Posted: Fri May 03, 2019 5:44 am
for me it's Bevel shader - ideally with possibility to blend it with textures so that we can create an imperfect beveling.
and then triplanar mapping:
https://github.com/LuxCoreRender/LuxCore/issues/153
and don't know if related but while you work with shading it might be the time to do this...?:
https://github.com/LuxCoreRender/LuxCore/issues/148
Posted: Tue May 07, 2019 8:24 am
Also shadow terminator treatment could be part of materials/shading reworking?
Posted: Wed May 08, 2019 8:59 am
by marcatore
Later than other people, that more or less I approve, below you'll find my suggestions.
Some quick description are more or less copied by the manual of another renderer. They are perfect for my daily job so I'd like to have in Luxcore. If something it's working really good I think it's good trying to make something really similar.
Obviously these are just proposal...so I don't know how much doable.
In any case these mine:
Workflow
- enable multiUV mapping
- autocoloring viewport mesh color according the median color of the albedo map (if not present, use the RGB color)
- Dreaming mode ON: actually not too much LuxCore development related but I dream a quick mapping system that uses a modifier to mapping objects, something like the 3dsmax UVWmap modifier. It should be really helpful and, in an architectural scenario, it really speeds up mapping process. The useful of modifier instead of a "simple" command is to be able to replicate the mapping from an object to others in a quick way and with a consistent and precise result.
Materials
Priority
- like lacilaci asked, reduce (or avoid) the dark terminator issue with glossy materials
Optional
-Double face material with blend option (mappable)
Textures
Priority
Triplanar Mapping
MultiSubTex = texture allows the user to control any parameter that can be mapped based on the Object ID or Face ID on which the final material is applied.
DistanceTex = is a procedural texture that returns a different color based on a point's distance to an object(s) specified in a selection list.
Dirtmap
Optional
SoftBox = is a procedural texture that can be used in an Area Light to create the illumination coming from a Soft Box light source
Posted: Fri May 17, 2019 7:11 am
Posted: Mon May 20, 2019 10:33 am
by Piita
Glass takes time to render so I was thinking if there is a way to speed that up with a material that assumes the glass has even thickness(such as car windows). Since it has even thickness luxcore might be able to calculate the refraction path as soon as the ray hits the material. You would get the ray path inside the glass as well as the path direction where it would exit the glass.
Would there be any speed increase if you are able to calculate these as the same time, instead of tracing the ray until it exits the glass and then calculate again when it exits?
Posted: Mon May 20, 2019 12:27 pm
Piita wrote: ↑Mon May 20, 2019 10:33 am
There is some shadow trick other renderers tend to use for glass (vray, corona) maybe that would be enough.
Posted: Mon May 20, 2019 12:53 pm
by marcatore
lacilaci wrote: ↑Mon May 20, 2019 12:27 pm
And not just shadow trick... there are some GI and samples tricks you can use if needed
Posted: Tue May 21, 2019 10:00 am
marcatore wrote: ↑Mon May 20, 2019 12:53 pm
Yes this once again goes back to this issue:
I'm a broken record at this point
... But again and again doing any archviz without this is pain to render. And I'm not even mentioning light linking etc(but I guess that's outside of 2.3 and currently only corona and vray have the luxury)
Posted: Thu Jun 13, 2019 9:14 am
by Egert_Kanep
Some more thoughts
A node for uv Islands. For assigning random colors or masking with using uv islands. Super advanced would be to select island you want. This output could also be used to manipulate and offset uv's, if that feature ever comes
uv seam detect- node for detecting uv seams and having width and smoothness control to make lines where uv seam are. For adding color variation to leave edges and stuff. Could help with some creative stuff
Another good feature would be a way to manipulate uv using math operations. I am thinking something alon the lines of Unreal engine. There users has just the uv gradient (that we already have in lux) and that defines how texture is mapped onto uv's. subtracting or adding R,G channels would offset it and multiply operations scale it. That way we could morph uv's with noise for example.
