Page 39 of 67
Posted: Thu Feb 18, 2021 10:39 pm
by patro
TAO wrote: Thu Feb 18, 2021 8:29 pm The bump on the image is very nice.
the famous sponza scene, I used glossy 2 to render the whole scene.. bitmap texuteres for diffuse, specular and bump. rendered for just 389 samples..
both rougness set to 0.98
Posted: Fri Feb 19, 2021 8:59 am
by TAO
patro wrote: Thu Feb 18, 2021 10:39 pm
Well done, i think the bump map on the columns still needs a little bit of work.
if i see the original render, maybe i can give you more suggestions.
Nice job.
Posted: Fri Feb 19, 2021 12:55 pm
by patro
TAO wrote: Fri Feb 19, 2021 8:59 am
Nice job.
i can give you the link of the geometries and textures.
https://github.com/jimmiebergmann/Sponza the texture here are *.tga
https://github.com/NCCA/Sponza the textures are *.png
about the render, what you see is the original render, I saved as jpg, I just added 0.5 gamma because it was saved not gamma corrected from 3ds max
about the bump texture i've used the blueish one as bitmap dragged into the bump channel
as you know there is no way to control the scale of the texture, but using the greyish one is the same.
Posted: Fri Feb 19, 2021 1:12 pm
by TAO
patro wrote: Fri Feb 19, 2021 12:55 pm
i download the model and try to import it but it has a normal index issue, and won't let me import the model.
Posted: Fri Feb 19, 2021 1:14 pm
by patro
TAO wrote: Fri Feb 19, 2021 1:12 pm
dowload the textures, i'll zip my scene. i rendered the sponza 1 layer
sponza layer is the original sponza model
Posted: Fri Feb 19, 2021 10:57 pm
by TAO
patro wrote: Fri Feb 19, 2021 1:14 pm dowload the textures, i'll zip my scene. i rendered the sponza 1 layer
it was on the wrong slot. I fixed a few issues and will send them to you later.
Posted: Fri Feb 19, 2021 11:29 pm
by Ericka
TAO wrote: Wed Feb 17, 2021 2:57 pm
Ericka wrote: Wed Feb 17, 2021 1:37 pm Awesome, finally. is there a place so we can help the project. We have a few request that we can pay for it to make it happen faster.
Thanks, Ericka.
I think there is a bounty source that you can help the project on it, you can find it on the forum and main website.
Awesome, i will try it. one question how should we use cloth shader is there any tutorial or video to show how shaders work. I notice if i chose standard renderer 3ds max will crush whit null material, it's not a big issue because no buddy use standard renderer ever but i just want to report it.
Thank you for for great work.
Posted: Sat Feb 20, 2021 7:49 am
by patro
TAO wrote: Fri Feb 19, 2021 10:57 pm
oh great! thank you!
Posted: Sat Feb 20, 2021 5:32 pm
by TAO
MaxToLux v0.8.2501-beta
Plugin Download link available for 3dsmax 2019-2020-2021 in a single installer package https://github.com/LuxCoreRender/MaxToLux/releases
New Features
Change default renders engine to PathCPU for better compatibility.
Change material preview renders engine to PathCPU for better compatibility.
Add support for lightmap and mesh light for all materials.
Brand new Null material.
Improvements
Better support for 3dsmax 2020 and 2021.
Speed up light map check for material by inverting parameters.
Fixed Bugs
Fix default auto light save option.
Fix OpenCL device save options.
Fixed null material conflict with standard and Vray renderer.
Fixed null material conflict with standard and standard renderer.
Many bug fixes and features.
Installer Improvements
Update installer to support new build.
Knowing issues
Lux Cameras Missing
The perspective camera can be rendered in the wrong way sometimes.
If the fileserver option is enabled when saving the project 3dsmax will crash next time trying to open the project.
Posted: Sat Feb 20, 2021 7:56 pm
by patro
hi,
great work thank you for the last build :) love the eifel tower render!
I did some test with the "bump", or i'm doing something wrong, or i have really no idea.
I will definitely understand it better once you'll zip the sponza scene back.
so for now i did a test with MaxToLux v0.8.2501-beta, but with previous build i achieved the same.
for the test renders, i'm using the brick normal and bump png textures which are in the sponza pack together with Lux carpaint shader.
first pic: bump channel -> bump bitmap
second pic: bump channel -> lux normal -> normal bitmap ->scale 1
third pic: bump channel -> lux normal -> normal bitmap ->scale 0.002
forth pic: bump channel -> normal bitmap (no lux normal map)
sixth pic: normal channel -> normal bitmap
I see that when i use the normal blueish bitmap in the normal slot or the way you showed me "bump channel -> lux normal -> normal bitmap" the bump looks the same on the ball, looking the way it should i think smooth, but outwardly (inverted)
while the greyish bump bitmap in the bump channel looks very harsh, but inwardly, so does the normal bitmap in the norrmal channel while looking less harsh.
