Page 2 of 2
Re: Liquid Volumes
Posted: Thu Nov 15, 2018 8:01 am
pulgasari wrote: ↑Wed Nov 14, 2018 10:42 pm
Am I right in that currently, many of the specular effects with prisms, etc, are not available in their full glory on the GPU, or am I just not getting how to do it as far as the rendering algorithms. Because they work for me on the CPU, but not the GPU.
Yes, CPU supports bidirectional path tracing and it is capable to render some light path simple path tracing can not.
Re: Liquid Volumes
Posted: Mon Nov 19, 2018 3:01 pm
by stanland
B.Y.O.B. wrote: ↑Tue Nov 13, 2018 1:18 pm
Here's an example:
Why when you disable Interior Volume from glass the IOR stays the same as in the (Luxcore volume nodes) but refractions are different? Do you have to use Interior Volume with clear glass?
Re: Liquid Volumes
Posted: Mon Nov 19, 2018 3:17 pm
Because the glass volume has a higher priority than the liquid volume, so it "cuts away" some of the liquid.
If you remove the glass, the liquid is no longer "cut away". This creates an invalid volume setup, the IOR on the boundaries is no longer computed correctly etc.
You don't have to use an interior volume in all cases, but in this case it's necessary. Or you have to model the scene differently.
