Error: OpenCl viewport render doesn't work
johannes.wilde
Post by johannes.wilde »
Hey there,
i can't figure out why my OpenCL viewport doesn't work, while final render works fine.
I tried it with 2.2beta2 and latest builds.
The console gives me this error output:
[PathOCLBaseRenderThread::0] Compiling kernels
[PathOCLBaseRenderThread::0] PathOCL kernel compilation error
ERROR clBuildProgram[CL_BUILD_PROGRAM_FAILURE]:
<kernel>:14318:88: error: too few arguments to function call, expected 11, have 10
Maybe someone can help me with this?
Cheers,
Johannes
Re: Error: OpenCl viewport render doesn't work
I think it has been fixed, have you tried a daily build (viewtopic.php?f=9&t=736) ?
johannes.wilde
Wow!
That's a fast reply!
I already have installed the newest builds. It does not work in my case.
It hangs with the same message.
Is there more to the log? Usually it should contain a traceback with the line of code that's failing.
johannes.wilde
[LuxCore][31.359] [PathOCLBaseRenderThread::0] Compiling kernels
[LuxCore][31.500] [PathOCLBaseRenderThread::0] PathOCL kernel compilation error
<kernel>:17360:6: error: expected ')'
bsdf,
<kernel>:17358:33: note: to match this '('
return SphereLight_Illuminate(
File "C:\Users\JXXs\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCoreLatest\engine\__init__.py", line 114, in view_update
viewport.view_update(self, context)
File "C:\Users\JXXs\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCoreLatest\engine\viewport.py", line 47, in view_update
engine.session = engine.exporter.update(context, engine.session, changes)
File "C:\Users\JXXs\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCoreLatest\export\__init__.py", line 257, in update
session = self._update_config(session, self.config_cache.props)
File "C:\Users\JXXs\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCoreLatest\export\__init__.py", line 358, in _update_config
session.Start()
RuntimeError: PathOCLBase kernel compilation error
[Engine/Viewport] Pausing session
I should have fixed the problem. The fix will be included in the next build (available in a couple of hours).
johannes.wilde
Hey there!
Thanks for the update, but it produces some new error- This is the output i get:
<kernel>:9414:30: warning: passing 'const __global float *' to parameter of type '__global float *' discards qualifiers
VSTORE3F(origP + uu * dpdu, &hitPoint->p.x);
<kernel>:94:47: note: passing argument to parameter 'p' here
void VSTORE3F(const float3 v, __global float *p) {
<kernel>:9415:17: error: read-only variable is not assignable
hitPoint->uv.u += uu;
<kernel>:9416:46: warning: passing 'const __global float *' to parameter of type '__global float *' discards qualifiers
VSTORE3F(normalize(origShadeN + uu * dndu), &hitPoint->shadeN.x);
<kernel>:9423:30: warning: passing 'const __global float *' to parameter of type '__global float *' discards qualifiers
VSTORE3F(origP + vv * dpdv, &hitPoint->p.x);
<kernel>:9424:17: error: read-only variable is not assignable
hitPoint->uv.u = origUV.s0;
<kernel>:9425:17: error: read-only variable is not assignable
hitPoint->uv.v += vv;
<kernel>:9426:46: warning: passing 'const __global float *' to parameter of type '__global float *' discards qualifiers
VSTORE3F(normalize(origShadeN + vv * dndv), &hitPoint->shadeN.x);
<kernel>:9432:18: warning: passing 'const __global float *' to parameter of type '__global float *' discards qualifiers
VSTORE3F(origP, &hitPoint->p.x);
<kernel>:9433:19: warning: passing 'const __global float *' to parameter of type '__global float *' discards qualifiers
VSTORE2F(origUV, &hitPoint->uv.u);
<kernel>:82:47: note: passing argument to parameter 'p' here
void VSTORE2F(const float2 v, __global float *p) {
<kernel>:14913:20: warning: passing 'const __global float *' to parameter of type '__global float *' discards qualifiers
VSTORE3F(shadeN, &hitPoint->shadeN.x);
<kernel>:14914:18: warning: passing 'const __global float *' to parameter of type '__global float *' discards qualifiers
VSTORE3F(dpdu, &hitPoint->dpdu.x);
<kernel>:14915:18: warning: passing 'const __global float *' to parameter of type '__global float *' discards qualifiers
VSTORE3F(dpdv, &hitPoint->dpdv.x);
RT OCL is broken here too.
But in my case Blender simply stops responding. Need to force close.
Post by marcatore »
The same here!
Blender sometimes hangs up and if I try to make a render I have this error.
This after downloading the latest BlendLuxCore from maintenance branch and latest luxcore openCl build
[LuxRays][89.045] [Device Quadro K5200 Intersect] Pixel Filter Distribution buff
er size: 33Kbytes
[LuxCore][89.045] [PathOCLBaseRenderThread::0] Defined symbols:  -D LUXRAYS_OPEN
CL_KERNEL -D SLG_OPENCL_KERNEL -D RENDER_ENGINE_PATHOCL -D PARAM_RAY_EPSILON_MIN
=1.000000e-05f -D PARAM_RAY_EPSILON_MAX=1.000000e-01f -D PARAM_LIGHT_WORLD_RADIU
S_SCALE=1.050000e+00f -D PARAM_ACCEL_MBVH -D PARAM_FILM_RADIANCE_GROUP_0 -D PARA
M_FILM_RADIANCE_GROUP_COUNT=1 -D PARAM_FILM_CHANNELS_HAS_ALBEDO -D PARAM_FILM_CH
ANNELS_HAS_AVG_SHADING_NORMAL -D PARAM_FILM_CHANNELS_HAS_NOISE -D PARAM_ENABLE_T
EX_CONST_FLOAT -D PARAM_ENABLE_TEX_CONST_FLOAT3 -D PARAM_ENABLE_TEX_IMAGEMAP -D
PARAM_ENABLE_TEX_NORMALMAP -D PARAM_ENABLE_TEX_FRESNELCOLOR -D PARAM_ENABLE_TEX_
FRESNELCONST -D PARAM_ENABLE_TEX_HSV -D PARAM_ENABLE_MAT_MATTE -D PARAM_ENABLE_M
AT_MIRROR -D PARAM_ENABLE_MAT_ARCHGLASS -D PARAM_ENABLE_MAT_MIX -D PARAM_ENABLE_
MAT_NULL -D PARAM_ENABLE_MAT_GLOSSY2 -D PARAM_ENABLE_MAT_METAL2 -D PARAM_ENABLE_
MAT_ROUGHGLASS -D PARAM_HAS_PASSTHROUGH -D PARAM_CAMERA_TYPE=0 -D PARAM_HAS_SPOT
LIGHT -D PARAM_HAS_TRIANGLELIGHT -D PARAM_HAS_IMAGEMAPS -D PARAM_IMAGEMAPS_PAGE_
0 -D PARAM_IMAGEMAPS_COUNT=1 -D PARAM_HAS_IMAGEMAPS_BYTE_FORMAT -D PARAM_HAS_IMA
GEMAPS_FLOAT_FORMAT -D PARAM_HAS_IMAGEMAPS_3xCHANNELS -D PARAM_HAS_IMAGEMAPS_WRA
P_REPEAT -D PARAM_HAS_BUMPMAPS -D PARAM_HAS_VOLUMES -D SCENE_DEFAULT_VOLUME_INDE
X=4294967295 -D PARAM_MAX_PATH_DEPTH=7 -D PARAM_MAX_PATH_DEPTH_DIFFUSE=5 -D PARA
M_MAX_PATH_DEPTH_GLOSSY=5 -D PARAM_MAX_PATH_DEPTH_SPECULAR=6 -D PARAM_RR_DEPTH=3
 -D PARAM_RR_CAP=5.000000e-01f -D PARAM_SQRT_VARIANCE_CLAMP_MAX_VALUE=1.236033e+
06f -D PARAM_IMAGE_FILTER_TYPE=5 -D PARAM_IMAGE_FILTER_WIDTH_X=1.500000e+00f -D
PARAM_IMAGE_FILTER_WIDTH_Y=1.500000e+00f -D PARAM_IMAGE_FILTER_PIXEL_WIDTH_X=1 -
D PARAM_IMAGE_FILTER_PIXEL_WIDTH_Y=1 -D PARAM_SAMPLER_TYPE=2 -D PARAM_SAMPLER_SO
BOL_STARTOFFSET=32 -D PARAM_PGIC_ENABLED -D PARAM_PGIC_DEBUG_NONE -D PARAM_PGIC_
INDIRECT_ENABLED -D PARAM_ELVC_GLOSSINESSTHRESHOLD=0.0f -D LUXCORE_NVIDIA_OPENCL
[LuxCore][89.045] [PathOCLBaseRenderThread::0] Compiling kernels
[LuxCore][89.170] [PathOCLBaseRenderThread::0] PathOCL kernel compilation error
<kernel>:9441:30: warning: passing 'const __global float *' to parameter of type
<kernel>:97:47: note: passing argument to parameter 'p' here
<kernel>:9442:17: error: read-only variable is not assignable
<kernel>:9443:46: warning: passing 'const __global float *' to parameter of type
<kernel>:9450:30: warning: passing 'const __global float *' to parameter of type
<kernel>:9451:17: error: read-only variable is not assignable
<kernel>:9452:17: error: read-only variable is not assignable
<kernel>:9453:46: warning: passing 'const __global float *' to parameter of type
<kernel>:9459:18: warning: passing 'const __global float *' to parameter of type
<kernel>:9460:19: warning: passing 'const __global float *' to parameter of type
<kernel>:85:47: note: passing argument to parameter 'p' here
<kernel>:15275:20: warning: passing 'const __global float *' to parameter of typ
<kernel>:15276:18: warning: passing 'const __global float *' to parameter of typ
<kernel>:15277:18: warning: passing 'const __global float *' to parameter of typ
  File "C:\Users\XXXXXXXXX\AppData\Roaming\Blender Foundation\Blender\2.
79\scripts\addons\BlendLuxCore\engine\__init__.py", line 85, in render_final
    final.render(self, scene)
79\scripts\addons\BlendLuxCore\engine\final.py", line 40, in render
    _render_layer(engine, scene, render_slot_stats)
79\scripts\addons\BlendLuxCore\engine\final.py", line 63, in _render_layer
    engine.session.Start()
ERROR: PathOCLBase kernel compilation error
marcatore wrote: Mon Jul 22, 2019 8:27 am The same here!
I should have fixed this problem too, it was introduced in the last patch and it was related to the usage of normal/bump mapping.
