Hello everyone. I made an animation with Blender and Luxcore.
Enjoy, and please leave a like.
https://www.youtube.com/watch?v=2zlEy3zdqns
Details;
Project built in Blender 2.91 and rendered with Blender 2.81 with Luxcorerenderer.
Render settings;
Render settings is 161 frames, 50 samples for per frame. Video framerate is 24 fps. Render resolution is 1920x1080 (1080p HD)
Used path tracing method with Sobol & Progressive pattern.
And a question how can i make this render more clean with less render time?
Animation about robots and Metal(music)
Re: Animation about robots and Metal(music)
very nice, i think it need better light and more time for render and it will be perfect. nice job.
Thank you so much : ) I have worked on it much time and at last i just think render it its okay. Because i got problems about Denoiser adjustments. Denoiser doesn't denoising much. But this is a short animation and it's okay : )
ROCK! : D
And just a question if there was a tutorial about these things is this was can be interesting for you? I thinking to start to do tutorials. Thanks.
Any type of high-quality tutorial will be great, if you have any questions about how you can make it better you can get help from tutorials that already exist or ask in this forum.
Hello, I will make tutorials aimed at an unusual and very different experience. I hope you will see it in the future. I am sure it will be very useful for the blender and luxcore community.
a tutorial will be great
Maybe you should try to rise samples - for example up to 256 or higher (512, 1024). Then use Sobol and Cache-friendly pattern, it's gives some busts to render speed.U7777 wrote: ↑Sat Mar 06, 2021 3:29 pm Render settings;
For simple renders no need in FullHD, make it 720p.
Set Clamping to 25~ value - fireflies should be gone.
Don't forget about Denoiser, it will smooth picture.
And if u have closed interior - try to use Caches - PhotonGI.
