Page 1 of 2
Learning the Velvet shader
Posted: Wed Jan 30, 2019 11:56 pm
by Racleborg
1000 samples. Path opencl Random. No Denoise.
I had been trying this with 2 or 3 velvet shaders with different Advanced values, then mixing them together with maps and Pointiness, but this one was done with a single Velvet shader and plugging a diffuse map (many thanks to Chocofur for the map) into a Band node and then into the Thickness socket. I would have liked the velvet to be a bit more plush and will try and obtain that next time.
Cheers all
Re: Learning the Velvet shader
Posted: Thu Jan 31, 2019 11:55 am
Looking good!
Posted: Thu Jan 31, 2019 1:09 pm
by FarbigeWelt
Racleborg wrote: Wed Jan 30, 2019 11:56 pm
Cheers all
Please, do not do you down yourself. This sofa‘s texture looks very great! I think you have topped yourself again with this excellent work!!
Posted: Thu Jan 31, 2019 1:44 pm
by Racleborg
Thank you B.Y.O.B and FarbigeWelt
Feeling more confident
, I'm thinking of creating a version which shows the fabrics on one side and the wooden frame on the other. It will be fun!
Posted: Fri Feb 01, 2019 1:45 pm
by Racleborg
This setup appears to be working for me: I have the Velvet node at it's default values (makes sense really).
The attached is just a very quick render.
Could someone please just let me know if there is anything wrong or could be improved on in the node setup. (I will probably add some painted textures later, using the same node method).
Many thanks
Posted: Fri Feb 01, 2019 1:55 pm
I think you can replace the rightmost band texture with ColorMix node, which is a bit faster to compute.
Posted: Fri Feb 01, 2019 2:02 pm
by Racleborg
That's interesting. Thanks, I'll do that.
Posted: Sat Feb 16, 2019 11:47 pm
by Lincoln Deen
looks really awesome
Posted: Sun Feb 17, 2019 10:51 am
by Racleborg
Lincoln Deen. Thank you
Posted: Tue Aug 13, 2019 8:19 pm
by Racleborg
I’ve been working on a couple of pieces of furniture and a chess set. Even though this is obviously far from done I really like Lux’s VELVET shader as it makes things so easy to do, so I’m grabbing the moment to show it off!
(on the small cushion).
