Hey all- here is a new tutorial I made about rendering jewelry in LuxCore using Blender.
https://youtu.be/4zf4jbV8BaM
Here are some example renders using some of the techniques I show in the tutorial. Make sure to click the images to see them better. They are a little compressed here.
Rendering Jewelry in LuxCore
Re: Rendering Jewelry in LuxCore
Amazing as always, I enjoyed it. keep up the good work.
avoid completely white and completely black areas.
there should be neither 0% nor 100%.
96% white - yes. 98% is a critical maximum.
the same applies to black.
Keep up the good work.
The second image - You have made the tutorial on youtube using white ground plane and HDRI.
Could you explain how to setup for the first image you have shared!!
I tried multiple things but cannot setup this kind of scene.
Thank you and keep it up!!
I used a dark HDRI (one of the Studio HDRIs from HDRI haven.com) and some point lights. I have some project files available on my gumroad https://app.gumroad.com/djtutorials?sort=page_layout
