Max 2020 dlo and Slate Editor Errors
DustinM
Post by DustinM »
Currently unusable. I removed Max to Arnold just in case. When loading Max 2020 "Error Loading LuxObjects.dlo" and here is the error in Slate Editor when opened. Nowhere am I seeing where to install files and if I have to install the core program as well for the plugin to work?
Re: Max 2020 dlo and Slate Editor Errors
DustinM wrote: Tue Jan 05, 2021 12:20 am Currently unusable. I removed Max to Arnold just in case. When loading Max 2020 "Error Loading LuxObjects.dlo" and here is the error in Slate Editor when opened. Nowhere am I seeing where to install files and if I have to install the core program as well for the plugin to work?
New Version will be available very soon. and you can use it with 3dsmax 2020 and 2021 with no issue.
for more information you can flow this thread :
viewtopic.php?f=5&t=1010&start=240#p27113
DustinM
Post by DustinM »
Thank you for the info. I have a new thread https://forums.luxcorerender.org/viewtopic.php?t=5789 since I upgraded to Max 2022.
