Test on scene downloaded for free.
I need to work out on shaders and knots.
- 1'58 " of cooking at -1920 * 1080
- Default render settings
- Post production Affinity Photo
What do you think?
Simple Test Scene
Re: Simple Test Scene
For me it is still difficult to manage the Denoise, which makes me lose all the details.
2500 samples, and this is the comparison.
Are there any strategies to remedy this?
may be try to render with more resolution then needed and downscale to required
In both scenes, OIDN denoise.
PetrT,in the last scene I used 5000 samples... 9minute for the render.
Just use the Blender compositor where you can mix raw with denoised result like 25:75 or something.Magog wrote: Thu Nov 28, 2019 4:39 pm For me it is still difficult to manage the Denoise, which makes me lose all the details.
5000 samples 9min is awesome
Which can I mix them with?
With 2 Rtx 2080 and AMD ryzen 2950X... Yes.
When in LuxCore the denoiser is activated, the render layers node in the compositor shows a "DENOISED" output, which you can mix with the image output (shows the undenoised render). (Somehow this does not automatically update after a new render, I always have to manipulate a node in order to get a screen refresh showing the intended result.)
