Page 5 of 11
Re: PhotonGI caustic cache re-factoring
Posted: Mon Sep 30, 2019 9:19 am
Dade wrote: Mon Sep 30, 2019 9:14 am
What do you mean ? Faster compared to ? The cache look up is done only for SDS paths so there are a lot less cache look up (I assume you mean this). However the cache creation time (and update) is exactly the same (a caustic is a caustic and I can not know if it will be seen trough a specular surface
Yes, in my pool scene I keep running out of Vram with a lot of photons, so I'm hoping if they're sds only I can use high photon numbers and keep rendering using openCL
Posted: Mon Sep 30, 2019 9:25 am
lacilaci wrote: Mon Sep 30, 2019 9:19 am
You are probably using too many photons: you can cut the amount of the photons and the updated period in half and obtain about the same result (using half of the ram) with a bit more overhead.
Posted: Mon Sep 30, 2019 9:28 am
Dade wrote: Mon Sep 30, 2019 9:25 am
hm, thanks for the tip, I forgot about update period settings...
next up, hybrid glass?
would like to render finals already
Posted: Mon Sep 30, 2019 9:32 am
lacilaci wrote: Mon Sep 30, 2019 9:28 am
Going to open a pool with some idea for v2.3, etc.
Posted: Mon Sep 30, 2019 12:07 pm
hm.. Something's not right here
useonlyforsds 0
useonlyforsds 1
volume setup
material setup
I'm not getting any light bounces within water
EDIT:
I get reflections back if I set light tracing glossiness threshold to 1 (I guess caustic cache uses same threshold value?)
volume still looks wrong
but rendering freezes at some point
Posted: Mon Sep 30, 2019 12:26 pm
by epilectrolytics
Dade wrote: Mon Sep 30, 2019 8:46 am
I have added the option to use the caustic cache only for SDS paths:
This is some serious beauty
This looks great!
When will the first v2.3alpha0 be released?
Posted: Mon Sep 30, 2019 12:49 pm
lacilaci wrote: Mon Sep 30, 2019 12:07 pm
There are two different properties for Caustic cache and Hybrid rendering at the moment. They must be set at the same value.
Posted: Mon Sep 30, 2019 1:09 pm
Dade wrote: Mon Sep 30, 2019 12:49 pm
Ok, but what about volumes? Everything is super dark if I enable sds only.
Posted: Mon Sep 30, 2019 1:42 pm
Actually even if you don't use any volume you will get very different lighting with sds only cache
useforsdsonly = 0
useforsdsonly = 1
Posted: Mon Sep 30, 2019 1:50 pm
lacilaci wrote: Mon Sep 30, 2019 1:42 pm
Very different lighting compared to ? If the only difference is useforsdsonly = 0/1 and you are keeping hybrid rendering enabled: you are rendering the normal caustics 2 times in one case.
