MaxLuxCore - 3ds Max Integration for LuxCore
Re: MaxLuxCore - 3ds Max Integration for LuxCore
Post by Dade » Thu Nov 07, 2019 4:26 pm
TAO wrote:
Thu Nov 07, 2019 1:21 pm
Can you show me any reference to how you do the image pipeline after rendering?
You can call Film::ExecuteImagePipeline(imagePipelineIndex) in order to run one of the pipelines you have defined and than you can collect the result by calling Film::GetOutput(OUTPUT_RGB_IMAGEPIPELINE,bufferPtr).
Post by TAO » Thu Nov 07, 2019 8:42 pm
Here is render.cfg
renderengine.type = "PATHCPU"
opencl.platform.index = "-1"
opencl.cpu.use = "1"
opencl.gpu.use = "1"
opencl.cpu.workgroup.size = "0"
opencl.gpu.workgroup.size = "0"
opencl.devices.select = "11"
batch.halttime = "0"
film.opencl.enable = "1"
film.opencl.platform = "-1"
film.opencl.device = "-1"
film.imagepipeline.0.0.type = "TONEMAP_AUTOLINEAR"
film.imagepipeline.0.1.type = "TONEMAP_LUXLINEAR"
film.imagepipeline.0.1.sensitivity = "100.0"
film.imagepipeline.0.1.exposure = "2.4"
film.imagepipeline.0.1.fstop = "2.8"
film.imagepipeline.0.2.type = "GAMMA_CORRECTION"
film.imagepipeline.0.2.value = "2.2"
film.imagepipeline.0.2.table.size = "4096"
film.imagepipeline.1.0.type = "INTEL_OIDN"
film.imagepipeline.1.1.type = "TONEMAP_AUTOLINEAR"
film.imagepipeline.1.2.type = "TONEMAP_LUXLINEAR"
film.imagepipeline.1.2.sensitivity = "100.0"
film.imagepipeline.1.2.exposure = "2.4"
film.imagepipeline.1.2.fstop = "2.8"
film.imagepipeline.1.3.type = "GAMMA_CORRECTION"
film.imagepipeline.1.3.value = "2.2"
film.imagepipeline.1.3.table.size = "4096"
film.height = "768"
film.width = "1024"
film.filter.type = "GAUSSIAN"
film.filter.xwidth = "1.000000"
film.filter.ywidth = "1.000000"
film.filter.gaussian.alpha = "0.100000"
lightstrategy.type = "UNIFORM"
sampler.type = "SOBOL"
scene.file = "scene.scn"
When i execute pipeline for index 0 its work
session->GetFilm().ExecuteImagePipeline(0);
session->GetFilm().GetOutput<float>(Film::OUTPUT_RGB_IMAGEPIPELINE, pixels);
But when i use index 1 plugin crash and give me error code for violation access on 0.fffffffffffff
I may miss something again.
Post by Dade » Thu Nov 07, 2019 10:44 pm
It is "film.imagepipelines.0.0.type", you are missing an "s". The missing "s" is leading to the second pipeline overwriting the first one. So you ask for a pipeline that doesn't exist and boom.
a1-kh
Post by a1-kh » Fri Nov 08, 2019 2:00 pm
Sorry to be late, these are some snapshots of the environment variables that i found
i don't know if these are the correct ones or the others .
Post by TAO » Sun Nov 10, 2019 1:11 pm
Thank you so much a1-kh.
I'll going to send you new installer and with new features soo you can test and see if installer work correctlly.
Post by TAO » Sun Nov 10, 2019 1:15 pm
Great, thanks.
I finished it but, I'm not satisfied with the results especially with depth.
Is there any option with OIDN denoiser so i can optimize it.
Camera Depth
Interior Danish Mood Scene
Post by Dade » Sun Nov 10, 2019 1:49 pm
You have strange color "quantization" effect. Can you post the scene in text format (i.e. .cfg, .scn, .ply, etc.) so I can try here and check what is going on :?:
Post by TAO » Sun Nov 10, 2019 2:20 pm
Yes about the color, i have some questions, please check the scene first.
Also if the camera changes the distance all light power will be effected and the renderer will get different results.
f.zip
(3.38 MiB) Downloaded 3 times
Everythings are same and only change is camera distance to objects.
Post by TAO » Sun Nov 10, 2019 9:06 pm
I think something's wrong with
scene.materials.Material_25.id = 6,728,256
, it should'nt be like this.
Post by Dade » Sun Nov 10, 2019 9:52 pm
You may have a problem with C locale, "." Vs. "," and other nation/language related stuff.
