MaxLuxCore - 3ds Max Integration for LuxCore
nigec
Re: MaxLuxCore - 3ds Max Integration for LuxCore
Post by nigec » Fri Apr 12, 2019 3:17 pm
try the most recent sdk, there's been some fixes to the old file parser
Also it looks like its using Linear tonemapping, try auto
Post by B.Y.O.B. » Fri Apr 12, 2019 4:09 pm
IIRC this plugin uses the LuxCore API directly, not through the LXS parser. I could be wrong though. By the way, TAO, can you upload your current progress into the repo at https://github.com/LuxCoreRender/MaxLuxCore?
TAO wrote:
Fri Apr 12, 2019 2:48 pm
it doesn't matter how much i try with last code, lights and meshes not going to work correctly except on special circumstances. Especially on the direct light area and segments on the edge of shadows.
It looks to me like the emitted power is simply too much. You could try to use a lower gain setting as a start.
Sounds like the terminator issue, probably amplified by the high brightness. It's not something that can be solved, but it should vanish once you fix the brightness issue.
Post by TAO » Mon Apr 15, 2019 9:13 pm
Issues solved, everything look's nice now.
All lights work perfectly
Gain/Power/Efficiency of light work nicely
Shadow on edge is clear now
No more burning on the direct light area
Lux Camera object almost finished
Lux Pano Camera object almost finished
As most part of the code is hard-code before uploading the code, i need to do some change and maybe add 2d/3d textures, Tonemap controller.
So we have working renderer, It will not take much time. ;)
here are a few renders.
multi-point light
sun and sky light
alpistinho
Post by alpistinho » Mon Apr 15, 2019 11:22 pm
Nice progress TAO!
Post by Sharlybg » Wed Apr 17, 2019 1:35 pm
Nice done Tao.
Will also be very good if you post here also , just a way keep the Hype generator turning :D :
https://blenderartists.org/t/luxcoreren ... 148794/146
Post by TAO » Fri Apr 19, 2019 2:56 pm
new parameters support for lights include Omni, Spotlight, Sky and Directional
Multiplier
Light Limits (Decay, Fade out, etc)
Position Animation + Target Position Animation
Post by TAO » Fri Apr 19, 2019 2:57 pm
Nice done Tao.
Sure, Thank you to point it out.
Post by Dade » Fri Apr 19, 2019 3:31 pm
Nice done Tao.
A 3ds Max forum may be even more appropriate (after all, BlenderArtist is a Blender focused forum).
Post by TAO » Sat Apr 20, 2019 2:01 pm
Something wrong with UV, all textures shows as color on any surface, it's like textures stretched or something like that.
The colorful texture appears as purple color and black and with one as gray.
Post by Dade » Sat Apr 20, 2019 4:22 pm
If you use the FILESAVER render engine to save the scene on files and post the files here, I can tell you what is going wrong.
