Page 16 of 17
Re: A baking test scene
Posted: Wed Sep 30, 2020 8:04 pm
Marcurion wrote: Wed Sep 30, 2020 4:16 pm I am new to LuxCore.
Could someone explain to me how I can get the light information baked to a texture for realtime graphics?
I already managed to set up everything in Blender :)
Unfortunately, baking is a feature that has not yet been exposed in BlendLuxCore. It has been developed, some time ago, for https://www.vectary.com.
I can explain you how to export the scene from blender, edit the scene files and to use command line tools to obtain the baked textures but it is a viable option only if you are something like a developer (i.e. it is going to be very annoying and confusing for a normal Blender user).
Posted: Wed Sep 30, 2020 8:48 pm
by Marcurion
Dade wrote: Wed Sep 30, 2020 8:04 pm
Oh that is fine, I am a programer, please go ahead...
Posted: Sat Oct 03, 2020 10:42 am
Marcurion wrote: Wed Sep 30, 2020 8:48 pm
The procedure to follow is described here: viewtopic.php?f=5&t=1577&start=50#p18250
You can also use test scenes available here with the above precedure: https://github.com/LuxCoreRender/LuxCor ... cenes/bake
Posted: Wed Oct 07, 2020 4:25 pm
by Marcurion
Dade wrote: Sat Oct 03, 2020 10:42 am
Hi Dade,
thank you for helping me out.
I am almost there. I encountered an issue with commas in my scene.cfg: viewtopic.php?t=330
And solved it by replacing them with nothing in the file.
Now there are basically two issues:
1) The luxcoreui crashes once it tries to bake the third object in my scene (the glass dice)
2) The floor texture which is baked before (it is flipped in x-Dimension currently) does not take into account the glass dice at all, not even as a shadow caster let alone for the nice light tracing effect I want to achieve :|
I attached my Blender scene and the LuxCore output, maybe you can have a look?
BakeTestDice.zip
(866.08 KiB) Downloaded 861 times
Kind regards,
Marcurion
Posted: Sat Oct 10, 2020 3:19 pm
Marcurion wrote: Wed Oct 07, 2020 4:25 pm I am almost there. I encountered an issue with commas in my scene.cfg: viewtopic.php?t=330
This should not happen if you are using the under development v2.5, are you ?
Marcurion wrote: Wed Oct 07, 2020 4:25 pm And solved it by replacing them with nothing in the file.
You .ply files a corrupted by "," inside numbers:
format binary_little_endian 1.0
comment Created by LuxRays v2.4
element vertex 9,954
property float x
property float y
property float z
property float nx
property float ny
property float nz
property float s
property float t
element face 18,432
property list uchar uint vertex_indices
end_header
Again, I assume you are using v2.4 :?:
Posted: Sun Aug 15, 2021 10:32 am
by u3dreal
Since I have a web 3D project I have been looking into texture baking.
And what can I say luxcore is a very good way to do it.
Thanks Dade !
Now that I figured out the workflow ..I have some problems with the exported gltf when importing into Blender.
Also it does not work in other programs. BabylonJS or Opencascade.
Python: Traceback (most recent call last):
  File "/Users/drquader/Desktop/Blender.app/Contents/Resources/2.93/scripts/addons/io_scene_gltf2/__init__.py", line 1050, in execute
    return self.import_gltf2(context)
  File "/Users/drquader/Desktop/Blender.app/Contents/Resources/2.93/scripts/addons/io_scene_gltf2/__init__.py", line 1064, in import_gltf2
    if self.unit_import(path, import_settings) == {'FINISHED'}:
  File "/Users/drquader/Desktop/Blender.app/Contents/Resources/2.93/scripts/addons/io_scene_gltf2/__init__.py", line 1084, in unit_import
    BlenderGlTF.create(gltf_importer)
  File "/Users/drquader/Desktop/Blender.app/Contents/Resources/2.93/scripts/addons/io_scene_gltf2/blender/imp/gltf2_blender_gltf.py", line 42, in create
    BlenderGlTF._create(gltf)
  File "/Users/drquader/Desktop/Blender.app/Contents/Resources/2.93/scripts/addons/io_scene_gltf2/blender/imp/gltf2_blender_gltf.py", line 49, in _create
    BlenderScene.create(gltf)
  File "/Users/drquader/Desktop/Blender.app/Contents/Resources/2.93/scripts/addons/io_scene_gltf2/blender/imp/gltf2_blender_scene.py", line 40, in create
    BlenderNode.create_vnode(gltf, 'root')
  File "/Users/drquader/Desktop/Blender.app/Contents/Resources/2.93/scripts/addons/io_scene_gltf2/blender/imp/gltf2_blender_node.py", line 51, in create_vnode
    BlenderNode.create_vnode(gltf, child)
  File "/Users/drquader/Desktop/Blender.app/Contents/Resources/2.93/scripts/addons/io_scene_gltf2/blender/imp/gltf2_blender_node.py", line 38, in create_vnode
    BlenderNode.create_object(gltf, vnode_id)
  File "/Users/drquader/Desktop/Blender.app/Contents/Resources/2.93/scripts/addons/io_scene_gltf2/blender/imp/gltf2_blender_node.py", line 58, in create_object
    obj = BlenderNode.create_mesh_object(gltf, vnode)
  File "/Users/drquader/Desktop/Blender.app/Contents/Resources/2.93/scripts/addons/io_scene_gltf2/blender/imp/gltf2_blender_node.py", line 207, in create_mesh_object
    mesh = BlenderMesh.create(gltf, pynode.mesh, pynode.skin)
  File "/Users/drquader/Desktop/Blender.app/Contents/Resources/2.93/scripts/addons/io_scene_gltf2/blender/imp/gltf2_blender_mesh.py", line 34, in create
    return create_mesh(gltf, mesh_idx, skin_idx)
  File "/Users/drquader/Desktop/Blender.app/Contents/Resources/2.93/scripts/addons/io_scene_gltf2/blender/imp/gltf2_blender_mesh.py", line 52, in create_mesh
    do_primitives(gltf, mesh_idx, skin_idx, mesh, tmp_ob)
  File "/Users/drquader/Desktop/Blender.app/Contents/Resources/2.93/scripts/addons/io_scene_gltf2/blender/imp/gltf2_blender_mesh.py", line 208, in do_primitives
    uvs = BinaryData.decode_accessor(gltf, prim.attributes['TEXCOORD_%d' % uv_i], cache=True)
  File "/Users/drquader/Desktop/Blender.app/Contents/Resources/2.93/scripts/addons/io_scene_gltf2/io/imp/gltf2_io_binary.py", line 82, in decode_accessor
    array = BinaryData.decode_accessor_obj(gltf, accessor)
  File "/Users/drquader/Desktop/Blender.app/Contents/Resources/2.93/scripts/addons/io_scene_gltf2/io/imp/gltf2_io_binary.py", line 102, in decode_accessor_obj
    buffer_data = BinaryData.get_buffer_view(gltf, accessor.buffer_view)
  File "/Users/drquader/Desktop/Blender.app/Contents/Resources/2.93/scripts/addons/io_scene_gltf2/io/imp/gltf2_io_binary.py", line 53, in get_buffer_view
    gltf.load_buffer(buffer_view.buffer)
  File "/Users/drquader/Desktop/Blender.app/Contents/Resources/2.93/scripts/addons/io_scene_gltf2/io/imp/gltf2_io_gltf.py", line 165, in load_buffer
    data = self.load_uri(buffer.uri)
  File "/Users/drquader/Desktop/Blender.app/Contents/Resources/2.93/scripts/addons/io_scene_gltf2/io/imp/gltf2_io_gltf.py", line 183, in load_uri
    return memoryview(base64.b64decode(data))
  File "/Users/drquader/Desktop/Blender.app/Contents/Resources/2.93/python/lib/python3.9/base64.py", line 87, in b64decode
    return binascii.a2b_base64(s)
binascii.Error: Incorrect padding
You can find the gltf exported from luxcoreui here
http://q3de.com/wp-content/uploads/2021/08/testbake.zip
It would be nice if you could have a look.
And how can I use Denoising ? will I have to add that manually to the bakeall.cfg ?
Using the textures manually in Blender works really well.
I also think this is a much underrated feature and thinking about integrating it into BlendLuxCore.
Here is the file exported from Blender with LuxCore textures in BabylonJS
Posted: Sun Aug 15, 2021 11:19 am
I will check, I was using official glTF file validator for checking LuxCore outputs (https://github.khronos.org/glTF-Validator/) so they should be correct.
Posted: Sun Aug 15, 2021 12:11 pm
by epilectrolytics
u3dreal wrote: Sun Aug 15, 2021 10:32 am I also think this is a much underrated feature and thinking about integrating it into BlendLuxCore.
Yes please :D
Thanks for your efforts!
Posted: Sun Aug 15, 2021 1:32 pm
by u3dreal
Dade wrote: Sun Aug 15, 2021 11:19 am I will check, I was using official glTF file validator for checking LuxCore outputs (https://github.khronos.org/glTF-Validator/) so they should be correct.
This site says there are errors in the asset container ...
the commandlinetool has no errors.
Thanks a lot !!
Getting the same error with windows and blender.
Denoising would be a great speedup.
Posted: Sun Aug 15, 2021 1:41 pm
by u3dreal
Yes please :D
Still thinking about how to do it. But the solution right now seems also really easy if the gltf export works correctly.
would be nice to have some settings for baking / denoising etc.
