SSS Dragon
SSS Dragon
Hi ! Just wanna share with you the render and the blend file of this SSS Dragon. feel free to download and play with it :
File Download :
https://drive.google.com/open?id=1SZYBE ... 8M50A4TdFz
File Download :
- FarbigeWelt
- Contact:
Re: SSS Dragon
Hi, Sharlybg. Very nice study. How to you make a model like that? Is this a 3D scan or sculpted?
MacBook Air with M1
MacBook Air with M1
Re: SSS Dragon
It's a 3D scan available for free here : http://threedscans.com/FarbigeWelt wrote: ↑Fri Jul 13, 2018 9:48 pm Hi, Sharlybg. Very nice study. How to you make a model like that? Is this a 3D scan or sculpted?
for more contents visit this link :
https://wiki.luxcorerender.org/External ... ces#Models
- FarbigeWelt
- Contact:
Re: SSS Dragon
Hi Sharlybg, thank you for the links!
MacBook Air with M1
MacBook Air with M1
Re: SSS Dragon
Thanks for the scene - this is very useful. Especially now, where I was experimenting with SSS and found it a little hard to understand.
One question. Initially my rendering was way too bright. I had my Color Management in Blender switched to sRGB. When I switched it to Filmic, I got about the same result as you have. I saw that your camera is set to "Linear. Do I have to use Filmic color management in Blender when the Camera is set to "Linear"? Is this the prefered workflow to get a good dynamic range?
Cheers,
Andreas
Cheers,
Andreas
Re: SSS Dragon
No, you don't have to.AndreasResch wrote: ↑Sat Jul 14, 2018 6:54 am Do I have to use Filmic color management in Blender when the Camera is set to "Linear"?
If you want to use sRGB and the result is too bright, use a lower gain value in the settings of the linear tonemapper.
Re: SSS Dragon
If I just lower the Gain value, the image gets darker but is way too contrasty compared to the finished rendering at the top. It gets a little better if I set the Gamma value in den Color Management to 2.2, but it looks closest to the version above, when I activate the Filmic color management.
Have you ever tested Luxcore in combination with the Filmic color management in Blender?
Cheers,
Andreas
Cheers,
Andreas
Re: SSS Dragon
I use filmic in this render and the final render get a tiny curve color correction in gimp. but normally my color management and my camera setting should be already in the blend fileAndreasResch wrote: ↑Sat Jul 14, 2018 10:39 am If I just lower the Gain value, the image gets darker but is way too contrasty compared to the finished rendering at the top. It gets a little better if I set the Gamma value in den Color Management to 2.2, but it looks closest to the version above, when I activate the Filmic color management.
Cheers,
Andreas
Linear gain ===>> 1 // auto bright ===>> disable
Color M ====>> filmic
Re: SSS Dragon
Hey. All the settings were loaded correctly except the settings for the Filmic color management. That one was set to sRGB. That's why the scene initially rendered too brightly on my machine.
Cheers for that nice scene,
Andreas
Andreas
Re: SSS Dragon
I took the liberty to reduce the size of your file by using shared mesh data (aka "Alt+D copies") for the dragons, and enabling compression when saving the file.
(The material link mode of the dragon objects had to be switched from "Data" to "Object" so they can still use different materials even with shared meshes)
https://drive.google.com/open?id=14gS2C ... KCeyDNvbcW
Note: Currently, BlendLuxCore does not export shared meshes as instances (which would save a lot of RAM).
However, I'm working on it in a branch: https://github.com/LuxCoreRender/BlendL ... _instances
If you want to use instancing in the current versions of BlendLuxCore, you need duplis, particles or group instances, but these do not allow different materials per instance.
