Yes, it is a single light source so something intended to accelerated many light sources renderings is useless. "Many" can be a quite small value as shown in my second test with a single cube but one single light source is really too small.
Direct Light Sampling Cache (aka Light cache part I)
Re: Direct Light Sampling Cache (aka Light cache part I)
I added the support for cache entries on volumes:
I added also an option to to enable/disable cache entries on volumes because it can easily lead to a LOT of entries:
I updated the first post in this thread with the properties used by DLSC.
Once BlendLuxCore supports is done, we can release an alpha to start testing this feature (OpenCL support will follow once the testing is done).
NICE we are ready
I find it a bit weird that the targetCacheHitRatio is expressed as a percentage in range 0..100, while all the others are in range 0..1
lightstrategy.targetcachehitratio = 99.5
Ok, lightstrategy.targetcachehitratio is now between [0, 1] like other parameters.B.Y.O.B. wrote: ↑Thu Jun 28, 2018 4:25 pm I find it a bit weird that the targetCacheHitRatio is expressed as a percentage in range 0..100, while all the others are in range 0..1Code: Select all
- FarbigeWelt
- Contact:
Question: Direct Light Sampling Cache (aka Light cache part I)
What if there were an individual cache radius for each light source, depending on the volume of a path render with depth 1? This might be done even recursively, starting with a large radius, stopping at a maximal number of chaches per visible scene and light sources.
MacBook Air with M1
MacBook Air with M1
Re: Question: Direct Light Sampling Cache (aka Light cache part I)
What is "the volume of a path render" ?FarbigeWelt wrote: ↑Sat Aug 04, 2018 7:44 am What if there were an individual cache radius for each light source, depending on the volume of a path render with depth 1? This might be done even recursively, starting with a large radius, stopping at a maximal number of chaches per visible scene and light sources.
- FarbigeWelt
- Contact:
If I knew what to read to learn more about render techniques I would.
Correct me if I'm wrong. Light path starts at a light source heading in one direction until it hits the surface of an object (omitting volumes), considering path =1, the ray ends at this surface. The difference between light source and surface has a length. If you take several rays from the same light source, each ray having another angle, and span a trianlge from one ray's end to the two most close neighboured ray's end until all ray's end are connected you get a surface. The space enclosed by this surface I meant to be the volume of a path render with depth 1.
A reasonable radius for the DLSC algorithm might be a calculated using this volume. Sure, with depth 1 it is not clear if the reflected ray will hit the sensor at depth 2. Whereas one is able to calculate cut surface of sensor and the path render depth 1 volume and derive origins of direct lights. A following path strategy may decrease rays from this origin by essential factors what releases capacity for rays starting around the surface of the path render depth 1 volume.
EDIT1: EDIT2:
For comparison, usual path render strategy are even with the speed of two GPU kind of useless. Once there was fire it kept you warm, cooked your meals, and spent you light. The light was sparesly and flickering but repelled the beasts. Passing centuries, hungry minds wandered in the deepest darkness of the night until some got stroken with the brightest flashes of dawnig age of electricity. Bulbs spread the world and entered households like saturated beams of rising sun behind a mountains shadow. Once revealed, electric light pushed mankind into restlesness, with pace and clock of a barking thunderstorm. Continous accelerating involves starving for endless energy and optimization. Continously improving people focused on endowing crystallized knowledge reaching for another climax on the way to speed of light.
MacBook Air with M1
MacBook Air with M1
- FarbigeWelt
- Contact:
I will illustrate in the next weeks what I meant.Dade wrote: ↑Sat Aug 04, 2018 8:45 amWhat is "the volume of a path render" ?FarbigeWelt wrote: ↑Sat Aug 04, 2018 7:44 am What if there were an individual cache radius for each light source, depending on the volume of a path render with depth 1? This might be done even recursively, starting with a large radius, stopping at a maximal number of chaches per visible scene and light sources.
MacBook Air with M1
MacBook Air with M1
