Setting Image for Spot Projector
I'm trying to set the Image of Spot Projector from the Python Console of Blender, with the following line of code:
bpy.data.lamps['Spot'].luxcore.image = bpy.data.images['AAA.png']
As a result, I get an error:
File "C:\Users\igall\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\properties\light.py", line 60, in update_image
if context.lamp:
AttributeError: 'Context' object has no attribute 'lamp'
Despite the error, the field is being updated:
But the render results are unstable: sometimes the rendered image comes out with the pattern, and sometimes without.
What could be the reason for the problem?
Is there a better way to set the Image of Spot Projector from the Python Console of Blender?
Many thanks!
Igal
if context.lamp:
Many thanks!
Igal
Re: Setting Image for Spot Projector
I fixed the exception being thrown and another issue.
However as you noted, it was only a "cosmetic" problem, since the image is still updated.
Maybe it is related to this issue: https://github.com/LuxCoreRender/BlendL ... issues/152
Is your image a generated image? If yes, try to save it to disk.
By the way, you can find all properties here: https://github.com/LuxCoreRender/BlendL ... properties
Here is the faulty "update_image()" method: https://github.com/LuxCoreRender/BlendL ... ght.py#L72
And this is the fix: https://github.com/LuxCoreRender/BlendL ... 313625f46e
Sounds strange and I doubt it has anything to do with the rest (doesn't matter if the image was changed from UI or from Python).
Thanks B.Y.O.B!
image_name = os.path.basename(pattern_path)
bpy.ops.image.open(filepath=image_name, directory=os.path.dirname(pattern_path),
files=[{"name": image_name}], relative_path=False, show_multiview=True)
Still, the pattern existence in the render results is unstable.
That's how my results look like. It is a scene with two cameras. Each camera yields randomly a result with or without the pattern.
What else could be possible to solve this please?
I took your fix and updated to the latest version.
I'm loading my image from the disk with the following lines of code:
Can you upload an example scene showing the problem?
Done.
Here is the link:
https://drive.google.com/file/d/1COTFuz ... sp=sharing
Important note:
The problem appeared on a Win10 x64 PC with GTX 1070 GPU and i7-8700K CPU
The problem didn't appear on a Win7 x64 PC with AMD Radeon R7 M360 GPU and i7-6600U CPU
To replicate the problem:
- Download and unzip
- In command line, go to the unzipped folder
- Run the following command:
blender.exe --background "LuxRenderTest.blend" --python "render_scene.py"
I also placed in the folder a Jupyter notebook script that opens and shows the multilayer EXRs, open_multilayer_exrs.ipynb
Igal
I'm not sure if this is a problem in BlendLuxCore or in your script.
I would recommend to change your set_module_coord_frames() function in the following way:
replace this:
with this:
Running operators might require to force a scene update in some cases.
image_utils avoids this: https://docs.blender.org/api/2.79/bpy_e ... utils.html
Your script also makes some other wonky assumptions, e.g. that one of the cameras is selected. I would change this.
By the way, to do correct stereo you should use camera shift in X direction to make the camera frustums overlap exactly (currently you have some overshoot left and right if I'm not mistaken).
This is my result:
replace this:
files=[{"name": image_name}], relative_path=True, show_multiview=True)
bpy.data.lamps['Spot'].luxcore.image = bpy.data.images[image_name]
from bpy_extras import image_utils
img = image_utils.load_image(image_name, os.path.dirname(pattern_path))
bpy.data.lamps['Spot'].luxcore.image = img
This is my result:
Thanks B.Y.O.B,
I have replaced the code as you suggested, but still sometimes on a faster computer one of the cameras is rendered without the pattern.
Given multiple cameras in the scene, is it possible to render them simultaneously, by a single Blender API call?
Or, should one organize a loop by cameras? In this case, should one use viewport?
It could be that because of this misunderstanding the rendering in the uploaded script sometimes goes wrong.
I believe that once it becomes clear I can write a correct script.
It seems that this is an important point to understand.
No you can't render simultaneously, and it is not necessary.
What I meant is that your script assumes that the camera is selected when the .blend file is opened. In my tests, I once saved the file with the spotlight selected, and the script failed.
You should access them by name, e.g. bpy.data.objects["CamLeft"], instead of bpy.context.object and assuming that it is the camera.
Then please do further tests.
If you can show that the problem is a bug in BlendLuxCore, I can help you again.
Thanks B.Y.O.B,
I did the corrections that you have suggested.
One or both of the cameras are now rendered without the pattern in about 50% of the runs.
I have uploaded here the new script + Blender model:
https://drive.google.com/open?id=16f1Ow ... EgsS7SrmJL
You can download and run it in the similar way like the previous one.
Best Regards,
Igal
I have done more tests. Now I have the same behavior on both computers.
Best Regards,
Igal
Please test your script with Cycles as render engine.
If it works ok there but not in BlendLuxCore, I will investigate.
