Indirect specular\glossy with alpha
Rivental1
Post by Rivental1 » Sat Jan 11, 2020 10:17 pm
Hello. Is it possible to get indirect glossy (or any other pass) with alpha? In cycles no. And it is strange for me, after usage v-ray , corona and physical render from cinema 4d where each pass it is image with transperent background. It is very usefull for compositing.
Re: Indirect specular\glossy with alpha
Post by B.Y.O.B. » Sun Jan 12, 2020 12:38 am
Can't you just use the output of the Alpha AOV in compositing?
Since an alpha channel needs memory, it would increase the memory usage a lot to add an alpha channel to each AOV.
But maybe I misunderstand what you mean.
Rivental1
Post by Rivental1 » Sun Jan 19, 2020 10:05 am
Thanks!
Well, now it looks like this:
So, how to remove black area and leave only glossy? I tried to add diffren keyers in compositor, but somehow they do not work.
Egert_Kanep
Post by Egert_Kanep » Tue Jan 21, 2020 7:22 am
No need to key, you could pull luminance key if really wanted. But aov's are supposed to be added together. Perhaps you need something else than indirect glossy
