Photographer Blender add-on now supports LuxCoreRender too
Posted: Tue Aug 20, 2019 6:55 pm
Chafouin's Photographer Blender add-on now supports LuxCoreRender too:
https://gumroad.com/l/FWQf
Re: Photographer Blender add-on now supports LuxCoreRender too
Posted: Thu Aug 22, 2019 12:21 am
by oldladyfear
that's awesome! will make compositing with real life photos much more intuitive.
Posted: Thu Jun 04, 2020 7:26 pm
by em3d
How physical lights are implemented in lux ?
it´s not clear for me in the video
Posted: Fri Jun 05, 2020 4:31 pm
by chafouin
When Photographer 3 was released, Physical Lights were not supported for LuxCore, this is why it's not visible in the video.
BlendLuxCore already has Physical Lights units, I added them for 2.3. Photographer users wanted to be able to switch between Cycles and LuxCore and keep the same lighting, so now Photographer Physical lights are available for LuxCore and work the same way as in Cycles. The only difference is that the BlendLuxCore light panel isn't hidden, you can just close it and only use the Physical Light panel (I leave it accessible because BlendLuxCore evolves so quickly that Photographer will probably not be able to keep up).
There are only a couple of caveats, but you will see warnings in the UI if settings are wrong: LuxCore image pipeline tonemapper needs to be set up properly and lights needs to be converted everytime you change engines.
Posted: Fri Jun 05, 2020 7:31 pm
by em3d
well that´s an answer..
thanks a lot
Posted: Sun Jun 07, 2020 6:10 pm
by Odilkhan Yakubov
@Chafouin, any link for the latest version of the addon?
Thanks.
Posted: Sun Jun 07, 2020 9:41 pm
by chafouin
New version is here:
https://gumroad.com/products/cQTgl/
The other link in the first post is the older free version 2.
