Re: LuxCore for Maya
Posted: Tue Mar 12, 2019 5:33 pm
Acasta69 is the hero we need
It is! I just found out about it's existanceDade wrote: Tue Mar 12, 2019 5:28 pm BTW, interesting initiative: https://www.vfxplatform.com (from the linked AutoDesk thread).
Look like a fresh juice on a sunny daymotaman wrote: Wed Mar 13, 2019 12:22 am i will be posting here.
https://github.com/motamano/MayaLuxCore
[LuxCore][5.554] Outputting film: pipeline_contour_lines.png type: 2
[LuxCore][5.741] Outputting film: IRRADIANCE.exr type: 23
[LuxCore][5.819] Outputting film: RAYCOUNT.exr type: 21
[LuxCore][5.866] Outputting film: RGB.exr type: 0
File "pyluxcore_demo.py", line 154, in <module> main()
File "pyluxcore_demo.py", line 141, in main
session.GetFilm().GetOutputFloat(pyluxcore.FilmOutputType.IRRADIANCE, buffer, 0)
RuntimeError: Unsupported data type in Film.GetOutputFloat(): array
[LuxCore][6.022] [Intel(R) HD Graphics 530 Intersect] Memory used for OpenCL image pipeline: 17477Kbytes
The data type used by the python demo code has been introduced in Python v3.x, you just need to use another data type for v2.7 (https://github.com/LuxCoreRender/LuxCor ... mo.py#L210). pyluxcore.pyd should be fine.
Thanks for explaining DadeDade wrote: Wed Mar 13, 2019 2:49 pm The data type used by the python demo code has been introduced in Python v3.x, you just need to use another data type for v2.7 (https://github.com/LuxCoreRender/LuxCor ... mo.py#L210). pyluxcore.pyd should be fine.
I tried to run the script but i getacasta69 wrote: Wed Mar 13, 2019 2:13 pm Here you can find binaries for Python 2.7:
https://www.dropbox.com/s/2dl2xobx926qx ... 27.7z?dl=0
Note that there is no pyluxcoretool.exe included.
Also note that numpy is required for pyluxcore to work.
I have tried to run the script that B.Y.O.B. linked here:
viewtopic.php?f=4&t=371&p=4098&hilit=Co ... put#p4116
Even if it gives an error at the end, overall it seems to work and produces correct output, so...
I hope these binaries work for you!![]()
I report the error here as reference:This does not happen when run from python 3.5.Code: Select all
[LuxCore][5.554] Outputting film: pipeline_contour_lines.png type: 2 [LuxCore][5.741] Outputting film: IRRADIANCE.exr type: 23 [LuxCore][5.819] Outputting film: RAYCOUNT.exr type: 21 [LuxCore][5.866] Outputting film: RGB.exr type: 0 Traceback (most recent call last): File "pyluxcore_demo.py", line 154, in <module> main() File "pyluxcore_demo.py", line 141, in main session.GetFilm().GetOutputFloat(pyluxcore.FilmOutputType.IRRADIANCE, buffer, 0) RuntimeError: Unsupported data type in Film.GetOutputFloat(): array [LuxCore][6.022] [Intel(R) HD Graphics 530 Intersect] Memory used for OpenCL image pipeline: 17477Kbytes
File "pyluxcoredemo.py", line 84
print<"Blob [0]:",endl="")
SyntaxError: invalid syntax
