Re: BlendLuxCore Development
Posted: Thu Apr 25, 2019 7:04 am
Awesome, BYOB. Thanks!
I really really appreciate this New adaptative Sampling improvement ! and Cache reusability feature is so amazingB.Y.O.B. wrote: Tue Apr 23, 2019 9:53 pm BlendLuxCore now supports the new adaptive sampling: http://forums.luxcorerender.org/viewtop ... 100#p12284
It is enabled by default if the sobol or random samplers are used.
I'm working on that right now.
Thanks a lot !I'm working on that right now.
No, because you will be using the FBX exporter bundled with Blender, which doesn't export the LuxCore node trees. (I'm not even sure it can export Cycles materials)Sharlybg wrote: Thu Apr 25, 2019 12:57 pm I just want to understand something : If i export a Blend file with luxcore shader set in FBX format do other 3D software can read the shader in FBX (example : MaxLuxcore reading Shader from imported file) ?
I was thinking about it and I guess that the adaptive sampling will behave a bit differently on Blender compared to Luxcoreui. Since many times the tone mapping is done on Blender based on the HDR image produced by LuxCoreRender, the adaptive sampling will not consider it. Maybe some heuristic could be developed for this case, but it would be good to test it.B.Y.O.B. wrote: Tue Apr 23, 2019 9:53 pm BlendLuxCore now supports the new adaptive sampling: http://forums.luxcorerender.org/viewtop ... 100#p12284
Or, have a fully featured standalone framebuffer with tonemapping on it's own (like a modified luxcoreui) like vray or corona has.alpistinho wrote: Thu Apr 25, 2019 2:36 pmI was thinking about it and I guess that the adaptive sampling will behave a bit differently on Blender compared to Luxcoreui. Since many times the tone mapping is done on Blender based on the HDR image produced by LuxCoreRender, the adaptive sampling will not consider it. Maybe some heuristic could be developed for this case, but it would be good to test it.B.Y.O.B. wrote: Tue Apr 23, 2019 9:53 pm BlendLuxCore now supports the new adaptive sampling: http://forums.luxcorerender.org/viewtop ... 100#p12284
I am starting to work on it, but it won't be ready for 2.2lacilaci wrote: Fri Apr 26, 2019 8:06 am Or, have a fully featured standalone framebuffer with tonemapping on it's own (like a modified luxcoreui) like vray or corona has.
Are you working on a better ui alpistinho?alpistinho wrote: Fri Apr 26, 2019 8:43 am I am starting to work on it, but it won't be ready for 2.2
