BlendLuxCore Development
juangea
Re: BlendLuxCore Development
Post by juangea » Sun Jan 31, 2021 5:01 pm
What versions do support that and what version don’t?
Also could be great to be able to enable/disable that export if it slows down a lot the export process :)
Post by B.Y.O.B. » Sun Jan 31, 2021 5:15 pm
Currently, fast export is supported for 2.82.7 and 2.83.*
This can be checked here: https://github.com/LuxCoreRender/BlendL ... rter.py#L9
There is a warning if custom normals increase the export time of a mesh by more than 0.3 seconds. In such a case, you can disable usage of custom normals from the mesh in Blender, e.g. by deleting them or by disabling the weighted normal modifier or whatever else is creating them.
juangea
Post by juangea » Sun Jan 31, 2021 5:51 pm
Ah, ok, si I assume that refers to the normals modifiers and the baked normals into the mesh, but the normal smoothing with angle works ok and does not affect, right? :)
Post by B.Y.O.B. » Sun Jan 31, 2021 6:34 pm
Yes, I mean the feature that is labeled "custom split normals" here: https://docs.blender.org/manual/en/late ... it-normals
juangea
Post by juangea » Tue Feb 02, 2021 10:14 am
Yep, that was what I was thinking about, perfect, then it's not a big deal, at least for us, since usually that kind of smoothing detail is done in some very specific models :)
Post by B.Y.O.B. » Tue Feb 02, 2021 1:11 pm
I have extended the FAQ with a few new topics: https://wiki.luxcorerender.org/BlendLuxCore_FAQ
1.2 Is there something like Cycles' Layer Weight/Fresnel/Facing node in LuxCore?
1.3 Can Cycles materials be used in BlendLuxCore?
1.4 Can 2D/3D mapping be driven by textures in LuxCore?
1.5 What can be done against fireflies/hotpixels?
If you can think of more topics that come up often and should be included there, let me know.
Post by Dade » Mon Feb 08, 2021 5:05 pm
I was recently trying to found a work around to CUDA/hardware texture map limit of supporting only 1, 2 or 4 channels texture maps and I looked at Cycles sources to check how they were solving this problem: apparently they don't.
I'm guessing Cycles stores RGB (i.e. 3 channels images) as 4 channels, wasting a 33% of GPU memory. Can someone confirm this ? It shouldn't be hard to test by using a very large texture map with 3 or 4 channels and checking the amount of GPU memory used: if the amount is the same, my theory is confirmed.
Post by TAO » Mon Feb 08, 2021 5:13 pm
Not sure about that but OpenColorIO color space can be a good solution, and as I can see many renderers and software support it natively.
Latest build Download link👇👇
https://forums.luxcorerender.org/viewto ... 378#p28378
Post by B.Y.O.B. » Mon Feb 08, 2021 7:51 pm
I did a test with the following scene:
Render on GPU only (CUDA) with Cycles.
Three versions of a 16000x16000 pixel image: 1 channel (black/white), 3 channels (RGB), 4 channels (RGBA).
Output resolution 100x100.
I have no precise measurements of the used GPU RAM, but the task manager graph shows that your suspicion is probably right, as there's no difference in memory usage between 3 and 4 channel images.
Post by TAO » Mon Feb 08, 2021 8:38 pm
Maybe if you try the same test in a bigger image size the difference can be more obvious.
The memory usage for the compare part is so small that hardly can be noticed.
