Page 30 of 32
Re: OpenImageDenoise
Posted: Fri May 31, 2019 4:32 pm
by provisory
Currently LuxCore always uses 1 in albedo channel for metals, however the OpenImageDenoise documentation says:
For metallic surfaces the albedo should be either the reflectivity at normal incidence (e.g. from the artist friendly metallic Fresnel model) or the average reflectivity; or if these are constant (not textured) or unknown, the albedo can be simply 1 as well.
https://github.com/OpenImageDenoise/oidn#albedo
Could we use the Color value in Metal Material node for albedo? (Whether it is textured or constant.)
Posted: Fri May 31, 2019 6:40 pm
Yes, we can (we wrote the code before some clarification was added to the documentation). I will be out of the town for few days so just ping me if I forget.
Posted: Fri May 31, 2019 8:03 pm
by provisory
Okay, thanks in advance!
Posted: Wed Jun 05, 2019 7:34 pm
by provisory
Posted: Thu Jun 06, 2019 9:01 am
Posted: Thu Jun 06, 2019 2:23 pm
by provisory
Thank you!
Posted: Wed Jun 12, 2019 9:36 am
by provisory
I know I'm insatiable, but could we use the blend of the reflected and transmitted albedos for perfect specular surfaces (mirror and not rough glass)?
The albedo for dielectric surfaces (e.g. glass) should be either 1 or, if the surface is perfect specular (i.e. has a delta BSDF), the Fresnel blend of the reflected and transmitted albedos (as previously discussed). The latter usually works better but only if it does not introduce too much additional noise due to random sampling. Thus we recommend to split the path into a reflected and a transmitted path at the first hit, and perhaps fall back to an albedo of 1 for subsequent dielectric hits, to avoid noise. The reflected albedo in itself can be used for mirror-like surfaces as well.
Posted: Wed Jun 12, 2019 9:57 am
by epilectrolytics
Yes me too!
We already had that in the initial implementation but it can cause noise in the albedo AOV and thus irritate OIDN, so it was removed again.
In my tests it worked well, especially with BiDir, when there is a glass object on a textured surface.
It could be implemented as an option with a checkbox in the blender panel, maybe deactivated by default.
Posted: Wed Jun 12, 2019 10:00 am
Let's not forget that if albedo has noise, final image will have noise. This can turn oidn useless. But if there's a way.
Posted: Wed Jun 12, 2019 10:26 am
by provisory
Optional solution would be perfect!
