Page 9 of 13
Re: Windows Build FAILED
Posted: Wed Apr 29, 2020 8:32 am
by PetrT
acasta69 wrote: Wed Apr 29, 2020 6:51 am
zuljin3d wrote: Tue Apr 28, 2020 11:56 pm
mib2berlin wrote: Tue Apr 28, 2020 9:28 pm
Hi, I test only small scenes but does anybody have the same performance boost like me?
It is about 1.8 times faster than OCL on my stone age GTX 760.
I have a similar boost result on my old (gtx960 4gb)
neo2068 wrote: Mon Apr 27, 2020 6:21 pm
I get errors with latest build and OpenCL and the food demo scene, too, e.g. PATHOCL:clFinish(CL_INVALID_COMMAND_QUEUE) or TILEPATHOCL: clEnqueueReadBuffer(CL_OUT_OF_RESOURCES). With cuda my GTX 780 is 1.5 times faster than the GTX 1080. Is it normal behaviour?
acasta69 wrote: Tue Apr 21, 2020 5:36 pm
Now, without native threads and samples/sec as reference, I have 12% faster performance with OpenCL [than with Cuda on GTX970]
It seems we have a wide variety of results, mostly improvements but not all of them.
Also a GTX780 faster than a 1080 is quite strange, isn't it? The 1080 has more Cuda cores and nearly double clock speed and memory bandwitdh than the 780.
may be GTX780 faster than a 1080 for next reason gtx780 have GK110(Kepler) stone and 1080 GP104-400 Pascal (architecture) and Cuda cores are not the same.
Such case was happend earlier
1 core Fermi = 3 cores Kepler
this info from
https://milovsky.ru/nvidia-6xx-cuda-problem/
Posted: Wed Apr 29, 2020 10:10 am
Sure something is wrong. it is not the 980 but the 1080.
Posted: Wed Apr 29, 2020 11:18 am
I should have fixed the OpenCL problem: it was a mess of alignment and size of a 64bit field (CPU, OpenCL and CUDA work in different ways
Posted: Wed Apr 29, 2020 12:56 pm
Dade wrote: Wed Apr 29, 2020 11:18 am
Well Done ! thanks
Posted: Wed Apr 29, 2020 1:01 pm
by epilectrolytics
Yep, confirmed with Benchmark scene on Win10PC: 4.6 vs 3.3 megasamples/s CUDA vs OCL.
Great work, big thanks!
Posted: Wed Apr 29, 2020 3:17 pm
epilectrolytics wrote: Wed Apr 29, 2020 1:01 pm
Apparently, it is even faster with the new under construction cache friendly Sobol sampler
Posted: Wed Apr 29, 2020 3:42 pm
by neo2068
Yes, the results are really strange. I get very low cuda performance in general with my builds compared to the azure build, factor 4 slower for the 1080. The OpenCL kernel compilation ended with the mentioned error messages. I tested various versions of cuda SDK (8.0, 10.1 and 10.2) and the results were all the same. An old build of LuxCoreUI from 14.04. before the cuda merge show a normal OpenCL behaviour.
Posted: Thu Apr 30, 2020 12:39 pm
by CodeHD
Ok, I've been roughly reading this over the last week. Now I have time again andcould finally try myself
Win10 + RTX2070
I installed CUDA SDK 10.2 and the latest studio driver 442.92
Then the latest BlendLuxCore and LuxCore_CUDA build, and I have 2.3 as well.
Didn't try compiling myself yet.
In the daily build, both the LuxBall and Canelle&Fromage test scenes show a 25% improvement with CUDA over OpenCl. (CPU disabled)
Then I tried OCl in V2.3 with the LuxBall scene. And indeed, I get the same performance as with CUDA in 2.4
Posted: Thu Apr 30, 2020 6:42 pm
by kintuX
Latest daily is broken...
0 Warning(s)
583 Error(s)
Time Elapsed 00:00:43.30
--- FATAL ERROR RUNNING CMAKE ---
Posted: Thu Apr 30, 2020 7:59 pm
You have posted an empty file. Anyway I'm fixing it.
