Page 11 of 11
Re: Windows Build FAILED
Posted: Fri May 22, 2020 12:45 pm
by acasta69
Dade wrote: ↑Fri May 22, 2020 10:45 am
@Acasta69, I'm starting to think that compilation problem on Azure is due to the use of a Linux OpenCL SDK on Windows. The error seems to suggest that and the compilation on Windows works fine here.
You should check the OpenCL headers, the definition of "cl_ulong" type should be like:
typedef unsigned __int64 cl_ulong;
I think I'm using this OpenCL SDK:
https://github.com/GPUOpen-LibrariesAnd ... K/releases
I was using the same SDK, but since I installed the CUDA SDK, NVIDIA OpenCL is found and used.
The definition in 'cl_platform.h' in both SDKs matches the one you posted above.
Compilation with OpenCL and with CUDA is ok, the problem is when OpenCL is disabled.
The cl headers are not loaded in that case, even if 'ocl.h' is included, so 'cl_ulong' is not defined.
Can it be that there's a typo in
here:
#if defined(SLG_OPENCL_KERNEL)
unsigned long pixelsIndex;
#else
cl_ulong pixelsIndex;
#endif
Are we using an OpenCL type even if we are not in an OpenCL kernel (i.e. defined(SLG_OPENCL_KERNEL) is false)?
Posted: Fri May 22, 2020 1:08 pm
acasta69 wrote: ↑Fri May 22, 2020 12:45 pm
Ah, ok, it makes sense, I was thinking the error was when compiling the OpenCL enabled version. Indeed, cl_ulong is an OpenCL data type and it is not defined when OpenCL is not enabled.
I pushed a fix.
Posted: Fri May 22, 2020 9:10 pm
by kintuX
acasta69 wrote: ↑Fri May 22, 2020 7:53 am
kintuX wrote: ↑Thu May 21, 2020 11:40 pm
So where are caches stored, so I can clear/ delete all & make proper comparison?
For LuxCore 2.3 it should be:
C:\Users\<username>\AppData\Local\Temp\kernel_cache
For v2.4 there are two locations:
C:\Users\<username>\AppData\Local\Temp\cuda_kernel_cache
C:\Users\<username>\AppData\Local\Temp\ocl_kernel_cache
Dade wrote: ↑Fri May 22, 2020 1:08 pm
I pushed a fix.
TYVM to both
Commit 93de16134
Posted: Tue Jun 02, 2020 7:59 pm
by kintuX
Me again
and a new problem
Build FAILED.
"C:\luxcorerender\WindowsCompile\Build_CMake\LuxCore\LuxRays.sln" (default target) (1) ->
"C:\luxcorerender\WindowsCompile\Build_CMake\LuxCore\samples\luxcorescenedemo\luxcorescenedemo.vcxproj.metaproj"
(default target) (15) ->
"C:\luxcorerender\WindowsCompile\Build_CMake\LuxCore\samples\luxcorescenedemo\luxcorescenedemo.vcxproj" (default
target) (24) ->
(Link target) ->
C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.tar
gets(720,5): error MSB6006: "link.exe" exited with code -1073741819. [C:\luxcorerender\WindowsCompile\Build_CMak
e\LuxCore\samples\luxcorescenedemo\luxcorescenedemo.vcxproj]
0 Warning(s)
1 Error(s)
Time Elapsed 00:03:26.63
--- FATAL ERROR RUNNING CMAKE ---
What to do?
Posted: Wed Jun 03, 2020 1:48 pm
by kintuX
Compiling after latest commits (772e5eed4 & 1e5801c63):
Build succeeded
Posted: Fri Jun 12, 2020 7:30 pm
by kintuX
w/ latest commit (4cb96ab42)
Build FAILED.
"C:\luxcorerender\WindowsCompile\Build_CMake\LuxCore\samples\luxcoredemo\luxcoredemo.vcxproj.metaproj" (default
target) (13) ->
"C:\luxcorerender\WindowsCompile\Build_CMake\LuxCore\samples\luxcoredemo\luxcoredemo.vcxproj" (default target) (
19) ->
(Link target) ->
c:\luxcorerender\luxcore\src\slg\core\sphericalfunction\sphericalfunction.cpp(130): fatal error C1001: An inte
rnal error has occurred in the compiler. [C:\luxcorerender\WindowsCompile\Build_CMake\LuxCore\samples\luxcoredem
o\luxcoredemo.vcxproj]
0 Warning(s)
1 Error(s)
Time Elapsed 00:03:45.01
Posted: Fri Jun 12, 2020 9:07 pm
It is the same error than before: "An internal error has occurred in the compiler". Your compiler is broken (or you have an hardware problem).
The build on Azure is working fine:
https://dev.azure.com/LuxCoreRender/Lux ... 34e5207e1b
Posted: Fri Jun 12, 2020 9:58 pm
by kintuX
OK. After restarting Windows "
Build succeeded."
Indeed, something got corrupt on my side & now I at least know what to do, if it happens again, so: "Thank you for the note."
