Compile on MacOS 10.13
Posted: Tue Dec 03, 2019 4:02 pm
Hello everyone ... it's been a long time but some of you might remember me ... from back in the days.
I'm in the process of compiling luxcore on osx 10.13 and i got quite far so far.
EDIT: It actually worked out ! Try it here http://q3de.com/research/luxcorerender-for-osx-10-13/
The deps compile without issue ...using the script and after compiling and installing oidn 1.1.0 in the macos dir and tweaking the Config_OSX.cmake ... cmake finds all the deps including oidn. I might add it to the build script if this works out.
After fixing src/luxcore/luxparser/luxparse.y line 20 like so
and src/luxrays/core/context.cpp line 52 like so since CL_PLATFORM_NOT_FOUND_KHR seems not to be defined.
luxcore compiles but leave me stranded during linking of luxcoreui and luxconsole with this stupid
"ld: symbol(s) not found for architecture x86_64" error.
It seems clang can not link oiio. Could it be a problem that all the deps are compiled staticly
and osx tries to link dynamicly ?? Is there a way to force static build with clang / osx ? a flag ?
Help would be very much apprechiated and if all works out fine i'm more than happy to build a release for 2.2 .
back again
u3dreal
here is that stupid error
-%name-prefix "luxcore_parserlxs_yy"
%name-prefix = "luxcore_parserlxs_yy"
- if (err.err() != CL_PLATFORM_NOT_FOUND_KHR)
throw;
//if (err.err() != CL_PLATFORM_NOT_FOUND_KHR)
// throw;
back again
u3dreal
[ 94%] Linking CXX executable ../../luxcoreconsole
Undefined symbols for architecture x86_64:
"OpenSubdiv::v3_4_0::Osd::OmpEvaluator::EvalStencils(float const*, OpenSubdiv::v3_4_0::Osd::BufferDescriptor const&, float*, OpenSubdiv::v3_4_0::Osd::BufferDescriptor const&, int const*, int const*, int const*, float const*, int, int)", referenced from:
bool OpenSubdiv::v3_4_0::Osd::OmpEvaluator::EvalStencils<OpenSubdiv::v3_4_0::Osd::CpuVertexBuffer, OpenSubdiv::v3_4_0::Osd::CpuVertexBuffer, OpenSubdiv::v3_4_0::Far::StencilTable>(OpenSubdiv::v3_4_0::Osd::CpuVertexBuffer*, OpenSubdiv::v3_4_0::Osd::BufferDescriptor const&, OpenSubdiv::v3_4_0::Osd::CpuVertexBuffer*, OpenSubdiv::v3_4_0::Osd::BufferDescriptor const&, OpenSubdiv::v3_4_0::Far::StencilTable const*, OpenSubdiv::v3_4_0::Osd::OmpEvaluator const*, void*) in libslg-core.a(subdiv.cpp.o)
"boost::system::detail::system_category_ncx()", referenced from:
OpenImageIO_v1_8::Filesystem::create_directory(OpenImageIO_v1_8::string_view, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >&) in libOpenImageIO.a(filesystem.cpp.o)
OpenImageIO_v1_8::Filesystem::copy(OpenImageIO_v1_8::string_view, OpenImageIO_v1_8::string_view, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >&) in libOpenImageIO.a(filesystem.cpp.o)
OpenImageIO_v1_8::Filesystem::rename(OpenImageIO_v1_8::string_view, OpenImageIO_v1_8::string_view, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >&) in libOpenImageIO.a(filesystem.cpp.o)
OpenImageIO_v1_8::Filesystem::remove(OpenImageIO_v1_8::string_view, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >&) in libOpenImageIO.a(filesystem.cpp.o)
OpenImageIO_v1_8::Filesystem::remove_all(OpenImageIO_v1_8::string_view, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >&) in libOpenImageIO.a(filesystem.cpp.o)
OpenImageIO_v1_8::Filesystem::temp_directory_path() in libOpenImageIO.a(filesystem.cpp.o)
OpenImageIO_v1_8::Filesystem::unique_path(OpenImageIO_v1_8::string_view) in libOpenImageIO.a(filesystem.cpp.o)
"boost::system::detail::generic_category_ncx()", referenced from:
boost::system::error_category::std_category::equivalent(int, std::__1::error_condition const&) const in libOpenImageIO.a(socketinput.cpp.o)
boost::system::error_category::std_category::equivalent(std::__1::error_code const&, int) const in libOpenImageIO.a(socketinput.cpp.o)
boost::system::error_category::std_category::equivalent(int, std::__1::error_condition const&) const in libOpenImageIO.a(socketoutput.cpp.o)
boost::system::error_category::std_category::equivalent(std::__1::error_code const&, int) const in libOpenImageIO.a(socketoutput.cpp.o)
boost::system::error_category::std_category::equivalent(int, std::__1::error_condition const&) const in libOpenImageIO.a(socket_pvt.cpp.o)
boost::system::error_category::std_category::equivalent(std::__1::error_code const&, int) const in libOpenImageIO.a(socket_pvt.cpp.o)
"Iex_2_3::throwErrnoExc()", referenced from:
OpenImageIO_v1_8::OpenEXRInputStream::OpenEXRInputStream(char const*) in libOpenImageIO.a(exrinput.cpp.o)
OpenImageIO_v1_8::OpenEXRInputStream::read(char*, int) in libOpenImageIO.a(exrinput.cpp.o)
OpenImageIO_v1_8::OpenEXRInputStream::seekg(unsigned long) in libOpenImageIO.a(exrinput.cpp.o)
OpenImageIO_v1_8::OpenEXROutputStream::OpenEXROutputStream(char const*) in libOpenImageIO.a(exroutput.cpp.o)
OpenImageIO_v1_8::OpenEXROutputStream::write(char const*, int) in libOpenImageIO.a(exroutput.cpp.o)
OpenImageIO_v1_8::OpenEXROutputStream::seekp(unsigned long) in libOpenImageIO.a(exroutput.cpp.o)
"Iex_2_3::BaseExc::BaseExc(char const*)", referenced from:
Imath_2_3::SingMatrixExc::SingMatrixExc(char const*) in libOpenImageIO.a(imagebufalgo_xform.cpp.o)
Iex_2_3::InputExc::InputExc(char const*) in libOpenImageIO.a(exrinput.cpp.o)
Iex_2_3::ErrnoExc::ErrnoExc(char const*) in libOpenImageIO.a(exroutput.cpp.o)
Iex_2_3::TypeExc::TypeExc(char const*) in libOpenImageIO.a(exroutput.cpp.o)
Imath_2_3::SingMatrixExc::SingMatrixExc(char const*) in libOpenImageIO.a(texturesys.cpp.o)
"Iex_2_3::BaseExc::~BaseExc()", referenced from:
Imath_2_3::SingMatrixExc::~SingMatrixExc() in libOpenImageIO.a(imagebufalgo_xform.cpp.o)
Iex_2_3::InputExc::~InputExc() in libOpenImageIO.a(exrinput.cpp.o)
Iex_2_3::ErrnoExc::~ErrnoExc() in libOpenImageIO.a(exroutput.cpp.o)
Iex_2_3::TypeExc::~TypeExc() in libOpenImageIO.a(exroutput.cpp.o)
OpenImageIO_v1_8::OpenEXRInput::read_native_deep_scanlines(int, int, int, int, int, OpenImageIO_v1_8::DeepData&) in libOpenImageIO.a(exrinput.cpp.o)
OpenImageIO_v1_8::OpenEXRInput::read_native_deep_tiles(int, int, int, int, int, int, int, int, OpenImageIO_v1_8::DeepData&) in libOpenImageIO.a(exrinput.cpp.o)
OpenImageIO_v1_8::OpenEXROutput::write_deep_scanlines(int, int, int, OpenImageIO_v1_8::DeepData const&) in libOpenImageIO.a(exroutput.cpp.o)
OpenImageIO_v1_8::OpenEXROutput::write_deep_tiles(int, int, int, int, int, int, OpenImageIO_v1_8::DeepData const&) in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::DeepFrameBuffer::insert(char const*, Imf_2_3::DeepSlice const&)", referenced from:
"Imf_2_3::TiledOutputFile::writeTiles(int, int, int, int, int, int)", referenced from:
OpenImageIO_v1_8::OpenEXROutput::write_tiles(int, int, int, int, int, int, OpenImageIO_v1_8::TypeDesc, void const*, long, long, long) in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::TiledOutputFile::setFrameBuffer(Imf_2_3::FrameBuffer const&)", referenced from:
"Imf_2_3::TiledOutputFile::TiledOutputFile(Imf_2_3::OStream&, Imf_2_3::Header const&, int)", referenced from:
OpenImageIO_v1_8::OpenEXROutput::open(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, OpenImageIO_v1_8::ImageSpec const&, OpenImageIO_v1_8::ImageOutput::OpenMode) in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::TiledOutputPart::writeTiles(int, int, int, int, int, int)", referenced from:
"Imf_2_3::TiledOutputPart::setFrameBuffer(Imf_2_3::FrameBuffer const&)", referenced from:
"Imf_2_3::TiledOutputPart::TiledOutputPart(Imf_2_3::MultiPartOutputFile&, int)", referenced from:
OpenImageIO_v1_8::OpenEXROutput::open(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, int, OpenImageIO_v1_8::ImageSpec const*) in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::globalThreadCount()", referenced from:
OpenImageIO_v1_8::OpenEXRInput::open(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, OpenImageIO_v1_8::ImageSpec&) in libOpenImageIO.a(exrinput.cpp.o)
"Imf_2_3::DeepTiledInputPart::setFrameBuffer(Imf_2_3::DeepFrameBuffer const&)", referenced from:
"Imf_2_3::DeepTiledInputPart::readPixelSampleCounts(int, int, int, int, int)", referenced from:
"Imf_2_3::DeepTiledInputPart::readTiles(int, int, int, int, int, int)", referenced from:
"Imf_2_3::DeepTiledInputPart::DeepTiledInputPart(Imf_2_3::MultiPartInputFile&, int)", referenced from:
OpenImageIO_v1_8::OpenEXRInput::seek_subimage(int, int, OpenImageIO_v1_8::ImageSpec&) in libOpenImageIO.a(exrinput.cpp.o)
"Imf_2_3::MultiPartInputFile::MultiPartInputFile(Imf_2_3::IStream&, int, bool)", referenced from:
"Imf_2_3::DeepTiledOutputPart::writeTiles(int, int, int, int, int, int)", referenced from:
"Imf_2_3::DeepTiledOutputPart::setFrameBuffer(Imf_2_3::DeepFrameBuffer const&)", referenced from:
"Imf_2_3::DeepTiledOutputPart::DeepTiledOutputPart(Imf_2_3::MultiPartOutputFile&, int)", referenced from:
"Imf_2_3::MultiPartOutputFile::MultiPartOutputFile(char const*, Imf_2_3::Header const*, int, bool, int)", referenced from:
"Imf_2_3::setGlobalThreadCount(int)", referenced from:
OpenImageIO_v1_8::pvt::set_exr_threads() in libOpenImageIO.a(exrinput.cpp.o)
"Imf_2_3::DeepScanLineInputPart::readPixels(int, int)", referenced from:
"Imf_2_3::DeepScanLineInputPart::setFrameBuffer(Imf_2_3::DeepFrameBuffer const&)", referenced from:
"Imf_2_3::DeepScanLineInputPart::readPixelSampleCounts(int, int)", referenced from:
"Imf_2_3::DeepScanLineInputPart::DeepScanLineInputPart(Imf_2_3::MultiPartInputFile&, int)", referenced from:
"Imf_2_3::DeepScanLineOutputPart::writePixels(int)", referenced from:
"Imf_2_3::DeepScanLineOutputPart::setFrameBuffer(Imf_2_3::DeepFrameBuffer const&)", referenced from:
"Imf_2_3::DeepScanLineOutputPart::DeepScanLineOutputPart(Imf_2_3::MultiPartOutputFile&, int)", referenced from:
"Imf_2_3::Slice::Slice(Imf_2_3::PixelType, char*, unsigned long, unsigned long, int, int, double, bool, bool)", referenced from:
OpenImageIO_v1_8::OpenEXRInput::read_native_scanlines(int, int, int, int, int, void*) in libOpenImageIO.a(exrinput.cpp.o)
OpenImageIO_v1_8::OpenEXRInput::read_native_tiles(int, int, int, int, int, int, int, int, void*) in libOpenImageIO.a(exrinput.cpp.o)
OpenImageIO_v1_8::OpenEXROutput::write_scanline(int, int, OpenImageIO_v1_8::TypeDesc, void const*, long) in libOpenImageIO.a(exroutput.cpp.o)
OpenImageIO_v1_8::OpenEXROutput::write_scanlines(int, int, int, OpenImageIO_v1_8::TypeDesc, void const*, long, long) in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::Header::compression()", referenced from:
OpenImageIO_v1_8::OpenEXROutput::put_parameter(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, OpenImageIO_v1_8::TypeDesc, void const*, Imf_2_3::Header&) in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::Header::setTileDescription(Imf_2_3::TileDescription const&)", referenced from:
OpenImageIO_v1_8::OpenEXROutput::spec_to_header(OpenImageIO_v1_8::ImageSpec&, int, Imf_2_3::Header&) in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::Header::insert(char const*, Imf_2_3::Attribute const&)", referenced from:
"Imf_2_3::Header::setType(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&)", referenced from:
"Imf_2_3::Header::channels()", referenced from:
"Imf_2_3::Header::lineOrder()", referenced from:
"Imf_2_3::Header::Header(Imath_2_3::Box<Imath_2_3::Vec2<int> > const&, Imath_2_3::Box<Imath_2_3::Vec2<int> > const&, float, Imath_2_3::Vec2<float> const&, float, Imf_2_3::LineOrder, Imf_2_3::Compression)", referenced from:
"Imf_2_3::Header::Header(Imf_2_3::Header const&)", referenced from:
std::__1::vector<Imf_2_3::Header, std::__1::allocator<Imf_2_3::Header> >::__append(unsigned long) in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::Header::Header(int, int, float, Imath_2_3::Vec2<float> const&, float, Imf_2_3::LineOrder, Imf_2_3::Compression)", referenced from:
"Imf_2_3::Header::~Header()", referenced from:
OpenImageIO_v1_8::OpenEXROutput::OpenEXROutput() in libOpenImageIO.a(exroutput.cpp.o)
OpenImageIO_v1_8::OpenEXROutput::init() in libOpenImageIO.a(exroutput.cpp.o)
OpenImageIO_v1_8::OpenEXROutput::~OpenEXROutput() in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::Header::operator=(Imf_2_3::Header const&)", referenced from:
"Imf_2_3::Channel::Channel(Imf_2_3::PixelType, int, int, bool)", referenced from:
"Imf_2_3::IStream::readMemoryMapped(int)", referenced from:
vtable for OpenImageIO_v1_8::OpenEXRInputStream in libOpenImageIO.a(exrinput.cpp.o)
"Imf_2_3::IStream::IStream(char const*)", referenced from:
"Imf_2_3::IStream::~IStream()", referenced from:
OpenImageIO_v1_8::OpenEXRInput::valid_file(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&) const in libOpenImageIO.a(exrinput.cpp.o)
OpenImageIO_v1_8::OpenEXRInputStream::~OpenEXRInputStream() in libOpenImageIO.a(exrinput.cpp.o)
"Imf_2_3::KeyCode::KeyCode(Imf_2_3::KeyCode const&)", referenced from:
"Imf_2_3::KeyCode::KeyCode(int, int, int, int, int, int, int)", referenced from:
Imf_2_3::TypedAttribute<Imf_2_3::KeyCode>::copy() const in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::KeyCode::operator=(Imf_2_3::KeyCode const&)", referenced from:
Imf_2_3::TypedAttribute<Imf_2_3::KeyCode>::copyValueFrom(Imf_2_3::Attribute const&) in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::OStream::OStream(char const*)", referenced from:
"Imf_2_3::OStream::~OStream()", referenced from:
OpenImageIO_v1_8::OpenEXROutputStream::~OpenEXROutputStream() in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::TimeCode::TimeCode(Imf_2_3::TimeCode const&)", referenced from:
OpenImageIO_v1_8::ImageSpec::metadata_val(OpenImageIO_v1_8::ParamValue const&, bool) in libOpenImageIO.a(formatspec.cpp.o)
OpenImageIO_v1_8::spec_to_xml(OpenImageIO_v1_8::ImageSpec const&, OpenImageIO_v1_8::ImageSpec::SerialVerbose) in libOpenImageIO.a(formatspec.cpp.o)
"Imf_2_3::TimeCode::TimeCode(unsigned int, unsigned int, Imf_2_3::TimeCode::Packing)", referenced from:
OpenImageIO_v1_8::DPXInput::seek_subimage(int, int, OpenImageIO_v1_8::ImageSpec&) in libOpenImageIO.a(dpxinput.cpp.o)
"Imf_2_3::TimeCode::TimeCode()", referenced from:
Imf_2_3::TypedAttribute<Imf_2_3::TimeCode>::copy() const in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::TimeCode::operator=(Imf_2_3::TimeCode const&)", referenced from:
Imf_2_3::TypedAttribute<Imf_2_3::TimeCode>::copyValueFrom(Imf_2_3::Attribute const&) in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::Attribute::Attribute()", referenced from:
Imf_2_3::TypedAttribute<Imf_2_3::Envmap>::copy() const in libOpenImageIO.a(exroutput.cpp.o)
Imf_2_3::TypedAttribute<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >::copy() const in libOpenImageIO.a(exroutput.cpp.o)
Imf_2_3::TypedAttribute<int>::copy() const in libOpenImageIO.a(exroutput.cpp.o)
Imf_2_3::TypedAttribute<float>::copy() const in libOpenImageIO.a(exroutput.cpp.o)
Imf_2_3::TypedAttribute<double>::copy() const in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::Attribute::~Attribute()", referenced from:
Imf_2_3::TypedAttribute<Imf_2_3::Envmap>::~TypedAttribute() in libOpenImageIO.a(exroutput.cpp.o)
Imf_2_3::TypedAttribute<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >::~TypedAttribute() in libOpenImageIO.a(exroutput.cpp.o)
Imf_2_3::TypedAttribute<int>::~TypedAttribute() in libOpenImageIO.a(exroutput.cpp.o)
Imf_2_3::TypedAttribute<float>::~TypedAttribute() in libOpenImageIO.a(exroutput.cpp.o)
Imf_2_3::TypedAttribute<double>::~TypedAttribute() in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::DeepSlice::DeepSlice(Imf_2_3::PixelType, char*, unsigned long, unsigned long, unsigned long, int, int, double, bool, bool)", referenced from:
"Imf_2_3::InputFile::readPixels(int, int)", referenced from:
"Imf_2_3::InputFile::setFrameBuffer(Imf_2_3::FrameBuffer const&)", referenced from:
"Imf_2_3::InputPart::readPixels(int, int)", referenced from:
"Imf_2_3::InputPart::setFrameBuffer(Imf_2_3::FrameBuffer const&)", referenced from:
"Imf_2_3::InputPart::InputPart(Imf_2_3::MultiPartInputFile&, int)", referenced from:
"Iex_2_3::BaseExc::what() const", referenced from:
vtable for Imath_2_3::SingMatrixExc in libOpenImageIO.a(imagebufalgo_xform.cpp.o)
vtable for Iex_2_3::InputExc in libOpenImageIO.a(exrinput.cpp.o)
vtable for Iex_2_3::ErrnoExc in libOpenImageIO.a(exroutput.cpp.o)
vtable for Iex_2_3::TypeExc in libOpenImageIO.a(exroutput.cpp.o)
vtable for Imath_2_3::SingMatrixExc in libOpenImageIO.a(texturesys.cpp.o)
"Imf_2_3::ChannelList::end() const", referenced from:
OpenImageIO_v1_8::OpenEXRInput::PartInfo::query_channels(OpenImageIO_v1_8::OpenEXRInput*, Imf_2_3::Header const*) in libOpenImageIO.a(exrinput.cpp.o)
"Imf_2_3::ChannelList::begin() const", referenced from:
"Imf_2_3::TypedAttribute<Imath_2_3::Box<Imath_2_3::Vec2<float> > >::writeValueTo(Imf_2_3::OStream&, int) const", referenced from:
vtable for Imf_2_3::TypedAttribute<Imath_2_3::Box<Imath_2_3::Vec2<float> > > in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::TypedAttribute<Imath_2_3::Box<Imath_2_3::Vec2<int> > >::writeValueTo(Imf_2_3::OStream&, int) const", referenced from:
vtable for Imf_2_3::TypedAttribute<Imath_2_3::Box<Imath_2_3::Vec2<int> > > in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::TypedAttribute<Imath_2_3::Vec2<double> >::writeValueTo(Imf_2_3::OStream&, int) const", referenced from:
vtable for Imf_2_3::TypedAttribute<Imath_2_3::Vec2<double> > in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::TypedAttribute<Imath_2_3::Vec2<float> >::writeValueTo(Imf_2_3::OStream&, int) const", referenced from:
vtable for Imf_2_3::TypedAttribute<Imath_2_3::Vec2<float> > in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::TypedAttribute<Imath_2_3::Vec2<int> >::writeValueTo(Imf_2_3::OStream&, int) const", referenced from:
vtable for Imf_2_3::TypedAttribute<Imath_2_3::Vec2<int> > in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::TypedAttribute<Imath_2_3::Vec3<double> >::writeValueTo(Imf_2_3::OStream&, int) const", referenced from:
vtable for Imf_2_3::TypedAttribute<Imath_2_3::Vec3<double> > in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::TypedAttribute<Imath_2_3::Vec3<float> >::writeValueTo(Imf_2_3::OStream&, int) const", referenced from:
vtable for Imf_2_3::TypedAttribute<Imath_2_3::Vec3<float> > in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::TypedAttribute<Imath_2_3::Vec3<int> >::writeValueTo(Imf_2_3::OStream&, int) const", referenced from:
vtable for Imf_2_3::TypedAttribute<Imath_2_3::Vec3<int> > in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::TypedAttribute<Imath_2_3::Matrix33<double> >::writeValueTo(Imf_2_3::OStream&, int) const", referenced from:
vtable for Imf_2_3::TypedAttribute<Imath_2_3::Matrix33<double> > in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::TypedAttribute<Imath_2_3::Matrix33<float> >::writeValueTo(Imf_2_3::OStream&, int) const", referenced from:
vtable for Imf_2_3::TypedAttribute<Imath_2_3::Matrix33<float> > in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::TypedAttribute<Imath_2_3::Matrix44<double> >::writeValueTo(Imf_2_3::OStream&, int) const", referenced from:
vtable for Imf_2_3::TypedAttribute<Imath_2_3::Matrix44<double> > in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::TypedAttribute<Imath_2_3::Matrix44<float> >::writeValueTo(Imf_2_3::OStream&, int) const", referenced from:
vtable for Imf_2_3::TypedAttribute<Imath_2_3::Matrix44<float> > in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::TypedAttribute<Imf_2_3::Chromaticities>::writeValueTo(Imf_2_3::OStream&, int) const", referenced from:
vtable for Imf_2_3::TypedAttribute<Imf_2_3::Chromaticities> in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::TypedAttribute<Imf_2_3::Envmap>::writeValueTo(Imf_2_3::OStream&, int) const", referenced from:
vtable for Imf_2_3::TypedAttribute<Imf_2_3::Envmap> in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::TypedAttribute<Imf_2_3::KeyCode>::writeValueTo(Imf_2_3::OStream&, int) const", referenced from:
vtable for Imf_2_3::TypedAttribute<Imf_2_3::KeyCode> in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::TypedAttribute<Imf_2_3::Rational>::writeValueTo(Imf_2_3::OStream&, int) const", referenced from:
vtable for Imf_2_3::TypedAttribute<Imf_2_3::Rational> in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::TypedAttribute<Imf_2_3::TimeCode>::writeValueTo(Imf_2_3::OStream&, int) const", referenced from:
vtable for Imf_2_3::TypedAttribute<Imf_2_3::TimeCode> in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::TypedAttribute<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >::writeValueTo(Imf_2_3::OStream&, int) const", referenced from:
vtable for Imf_2_3::TypedAttribute<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::TypedAttribute<std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >::writeValueTo(Imf_2_3::OStream&, int) const", referenced from:
vtable for Imf_2_3::TypedAttribute<std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > in libOpenImageIO.a(exroutput.cpp.o)
"Imf_2_3::MultiPartInputFile::parts() const", referenced from:
"Imf_2_3::MultiPartInputFile::header(int) const", referenced from:
"Imf_2_3::Header::dataWindow() const", referenced from:
OpenImageIO_v1_8::OpenEXRInput::PartInfo::parse_header(OpenImageIO_v1_8::OpenEXRInput*, Imf_2_3::Header const*) in libOpenImageIO.a(exrinput.cpp.o)
"Imf_2_3::Header::displayWindow() const", referenced from:
"Imf_2_3::Header::tileDescription() const", referenced from:
"Imf_2_3::Header::hasTileDescription() const", referenced from:
"Imf_2_3::Header::end() const", referenced from:
"Imf_2_3::Header::name() const", referenced from:
"Imf_2_3::Header::type() const", referenced from:
"Imf_2_3::Header::begin() const", referenced from:
"Imf_2_3::Header::hasName() const", referenced from:
"Imf_2_3::Header::channels() const", referenced from:
"Imf_2_3::IStream::isMemoryMapped() const", referenced from:
"Imf_2_3::KeyCode::perfOffset() const", referenced from:
"Imf_2_3::KeyCode::filmMfcCode() const", referenced from:
"Imf_2_3::KeyCode::perfsPerCount() const", referenced from:
"Imf_2_3::KeyCode::perfsPerFrame() const", referenced from:
"Imf_2_3::KeyCode::count() const", referenced from:
"Imf_2_3::KeyCode::prefix() const", referenced from:
"Imf_2_3::KeyCode::filmType() const", referenced from:
"Imf_2_3::TimeCode::timeAndFlags(Imf_2_3::TimeCode::Packing) const", referenced from:
"Imf_2_3::TimeCode::frame() const", referenced from:
OpenImageIO_v1_8::DPXInput::get_timecode_string(Imf_2_3::TimeCode&) in libOpenImageIO.a(dpxinput.cpp.o)
"Imf_2_3::TimeCode::hours() const", referenced from:
"Imf_2_3::TimeCode::minutes() const", referenced from:
"Imf_2_3::TimeCode::seconds() const", referenced from:
"Imf_2_3::TimeCode::userData() const", referenced from:
"Imf_2_3::TimeCode::dropFrame() const", referenced from:
"typeinfo for Iex_2_3::BaseExc", referenced from:
typeinfo for Iex_2_3::MathExc in libOpenImageIO.a(imagebufalgo_xform.cpp.o)
typeinfo for Iex_2_3::InputExc in libOpenImageIO.a(exrinput.cpp.o)
typeinfo for Iex_2_3::ErrnoExc in libOpenImageIO.a(exroutput.cpp.o)
typeinfo for Iex_2_3::TypeExc in libOpenImageIO.a(exroutput.cpp.o)
typeinfo for Iex_2_3::MathExc in libOpenImageIO.a(texturesys.cpp.o)
"typeinfo for Imf_2_3::IStream", referenced from:
typeinfo for OpenImageIO_v1_8::OpenEXRInputStream in libOpenImageIO.a(exrinput.cpp.o)
"typeinfo for Imf_2_3::OStream", referenced from:
typeinfo for OpenImageIO_v1_8::OpenEXROutputStream in libOpenImageIO.a(exroutput.cpp.o)
"typeinfo for Imf_2_3::Attribute", referenced from:
Imf_2_3::TypedAttribute<Imf_2_3::Envmap> const* Imf_2_3::Header::findTypedAttribute<Imf_2_3::TypedAttribute<Imf_2_3::Envmap> >(char const*) const in libOpenImageIO.a(exrinput.cpp.o)
Imf_2_3::TypedAttribute<Imf_2_3::Compression> const* Imf_2_3::Header::findTypedAttribute<Imf_2_3::TypedAttribute<Imf_2_3::Compression> >(char const*) const in libOpenImageIO.a(exrinput.cpp.o)
Imf_2_3::TypedAttribute<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > const* Imf_2_3::Header::findTypedAttribute<Imf_2_3::TypedAttribute<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > >(char const*) const in libOpenImageIO.a(exrinput.cpp.o)
Imf_2_3::TypedAttribute<int> const* Imf_2_3::Header::findTypedAttribute<Imf_2_3::TypedAttribute<int> >(char const*) const in libOpenImageIO.a(exrinput.cpp.o)
Imf_2_3::TypedAttribute<float> const* Imf_2_3::Header::findTypedAttribute<Imf_2_3::TypedAttribute<float> >(char const*) const in libOpenImageIO.a(exrinput.cpp.o)
Imf_2_3::TypedAttribute<Imath_2_3::Matrix33<float> > const* Imf_2_3::Header::findTypedAttribute<Imf_2_3::TypedAttribute<Imath_2_3::Matrix33<float> > >(char const*) const in libOpenImageIO.a(exrinput.cpp.o)
Imf_2_3::TypedAttribute<Imath_2_3::Matrix44<float> > const* Imf_2_3::Header::findTypedAttribute<Imf_2_3::TypedAttribute<Imath_2_3::Matrix44<float> > >(char const*) const in libOpenImageIO.a(exrinput.cpp.o)
clang: error: linker command failed with exit code 1 (use -v to see invocation)
make[2]: *** [luxcoreconsole] Error 1
make[1]: *** [samples/luxcoreconsole/CMakeFiles/luxcoreconsole.dir/all] Error 2
make: *** [all] Error 2
