MaxToLux - 3ds Max Integration for LuxCore
Re: MaxToLux - 3ds Max Integration for LuxCore
Post by TAO » Sun Jun 21, 2020 6:15 pm
Add support for volumetric materials.
Laser + Dust render test.
Download link to last MaxToLux build.👇👇
viewtopic.php?f=5&t=1010&start=160#p22925
a1-kh
Post by a1-kh » Mon Jun 22, 2020 5:39 pm
nice work :o
These are some nice lasers :o :o
May the force be with you 8-) 8-) 8-) 8-)
are there any builds to test, last one was 0.0.4. and what about the slow performance on bucket rendering, i hope it can be fixed :?
Ericka
Post by Ericka » Tue Jun 23, 2020 11:00 pm
Amazing work, I can't wait to test new features. :)
patro
Post by patro » Mon Jul 06, 2020 6:13 pm
TAO wrote:
Sat May 16, 2020 2:10 pm
MaxToLux beta V0.0.4 3dsmax 2019
it's still for test use and not for final production.
https://3dfine.com/down/lux/MaxToLux-Beta v0.0.4.zip
Simple Material Scene.
https://3dfine.com/down/lux/MaterialTest.zip
Hi TAO,
nice to see that the plugin project for 3ds max isn't dead.
I noticed in the material test image that the testers are all faceted and not smooth, is it on purpose?
thanks
Post by TAO » Tue Jul 07, 2020 9:12 am
It was a problem with smoothing faces, I already fixed it and in a new build, you can render both smooth and hard surfaces at the same time.
I planed to release new build but there are too many parameters to support and also working with 3dsmax parameters it's a bit time-consuming.
I'll try my best to release a new build soon.
This is the new preview and smooth surface.
Post by TAO » Tue Jul 07, 2020 9:16 am
You can expect lots of bug fixes, Also, support for almost all the LuxCoreRendere lights, shaders plus camera volumetric effects such as dust.
Still, many parameters left and I'm a busy alone developer. ;)
patro
Post by patro » Mon Jul 13, 2020 5:43 pm
Tao, that is great! :)
great job!
dragon32
Post by dragon32 » Fri Jul 31, 2020 4:47 pm
Hi, thank you very much Tao for your work. A simple DOF test after some crash of 3ds max, I was unable to use an HDRI for the environment in any way
patro
Post by patro » Wed Aug 12, 2020 12:59 pm
Hi Tao, i see the maxTolux is for max 2019.
I'm still on 2018, are you going to release a final version for max 2020/21?
or it will be compatible with the lates max versions?
