a1-kh
Post
by a1-kh » Sat Nov 30, 2019 9:37 pm
TAO wrote: ↑Sat Nov 30, 2019 7:00 pm
first, check if the material editor set to LuxMaxCore in the renderer options.
if it does not work tried to update to the new version and update material previews.
if it doesn't working again let me know.
Thank you.
Thanks TAO .. i tried you suggestions , still got the problem.
I tried to unlock the Material Editor Renderer , change it to several renderers, lock it back to the LuxMark renderer, still the same problem.
I hope it is an easy bug to fix
Best regards
- Note 2 : If you can change the installer name to LuxMaxCore so it would be easier to find in the Program Uninstaller .
- Note 1 : Installer still gives the Program Files(86x) path
