Issues with Sun and Distant light
Posted: Tue Feb 26, 2019 10:59 pm
I was just playing around with glass and caustics and noticed the following two things with Sun and Distant light:
Setup (.blend attached):
- Diffuse Plane
- Glass Cylinder vertically above
- Sun source shining down vertically.
- BiDir of course for the caustics, any sampler
- v2.2alpha0 and a late 2.1 daily build
Issue #1:
The cylinder shouldn't cause much attenuation of light as the Sunlight is passing throgh 2 perpendicular surfaces. A bit darker underneath maybe due to Fresnel reflections sending some light back.
With the default Sun this looks as expected: With the relative size set to 0.1, the circle underneath becomes brighter than the plane With the distant source, this behaviour seems a bit worse, being visible at a size (half angle) of 0.25 degree, like the Sun. Issue #2:
In the image with the distant source, notice how the plane gets darker away from the camera. This shouldn't be the case for a matte surface illuminated homogeneously.
Observations:
- Only happens with BiDir, not Path
- Independent of sampler and its settings.
- Only happens with distant, not Sun
- Diffuse Plane
Issue #1:
Observations:
