Dark poly spot
Posted: Fri Sep 11, 2020 2:45 pm
I struggling with a dark poly spot in my model in both blendluxcore 2.4 / 2.5 on CPU / GPU not in Cycles:
Dade PM you with the file.
Re: Dark poly spot
Posted: Sun Sep 13, 2020 2:25 pm
Exporting the scene to file system and rendering with LuxCoreUI works fine. The problem is visible only inside Blender.
Try to isolate the polygon with the problem and erase everything else.
Re: Dark poly spot
Posted: Wed Sep 16, 2020 9:42 am
Dade wrote: Sun Sep 13, 2020 2:25 pm Exporting the scene to file system and rendering with LuxCoreUI works fine. The problem is visible only inside Blender.
Another user is runing in the same issue : viewtopic.php?f=10&t=2584&p=25383#p25383
here is the mesh with isolated wrong surfaces :
Darkspot bug.blend
(790.35 KiB) Downloaded 526 times
Re: Dark poly spot
Posted: Wed Sep 16, 2020 10:55 am
Sharlybg wrote: Wed Sep 16, 2020 9:42 am
Darkspot bug.blend
The triangles have NaN UV coordinates:
ply
format ascii 1.0
comment Created by Blender 2.83.5 - www.blender.org, source file: 'Darkspot bug.blend'
element vertex 96
property float x
property float y
property float z
property float nx
property float ny
property float nz
property float s
property float t
element face 24
property list uchar uint vertex_indices
end_header
-0.291856 -0.093864 0.682044 -0.032319 -0.999451 0.000000 nan nan
-0.300529 -0.093583 0.498582 -0.032319 -0.999451 0.000000 nan nan
-0.264689 -0.094742 0.507916 -0.032319 -0.999451 0.000000 nan nan
-0.263646 -0.094776 0.759046 -0.032319 -0.999451 0.000000 nan nan
-0.301779 -0.093543 0.299369 -0.032319 -0.999451 0.000000 nan nan
-0.264892 -0.094736 0.299369 -0.032319 -0.999451 0.000000 nan nan
This is a .ply file directly exported from Blender without the use of any LuxCore related code. It is a Blender bug as far as I can see.
You can report the problem to Blender developers by providing this file a telling them to export in .ply format and check the UV coordinates (aka ST coordinates).
However they may be not able to track the problem from there because the NaN may be the result of the process used to build the mesh (so they may be unable to track what tool is broken and has generated the NaN).
Re: Dark poly spot
Posted: Wed Sep 16, 2020 11:54 am
Thanks Dade it is done here : https://developer.blender.org/T80835
Re: Dark poly spot
Posted: Wed Sep 16, 2020 12:26 pm
by Leandro Oliveira
What does NaN mean?
Re: Dark poly spot
Posted: Wed Sep 16, 2020 12:52 pm
Answer from brecht :
This is correct. This bug report requires steps to get a mesh into a state where UVs are NaN, otherwise we can't investigate it.
Re: Dark poly spot
Posted: Wed Sep 16, 2020 1:07 pm
Ok so a simple unwrapp can fix the issue :D And it work !
Re: Dark poly spot
Posted: Wed Sep 16, 2020 1:12 pm
Leandro Oliveira wrote: Wed Sep 16, 2020 12:26 pm What does NaN mean?
Not a Number.
It is usually the result of an invalid computation, e.g. division by zero.
Re: Dark poly spot
Posted: Wed Sep 16, 2020 1:23 pm
by Leandro Oliveira
Thanks, B.Y.O.B.! ;)
