Page 2 of 3
Re: Luxcore is very slow and freezes
Posted: Thu Mar 26, 2020 3:28 pm
I've deleted the next lines to stay in the allowed character
Hm, this is where it gets interesting.
Can you make another post with that part of the log?
Posted: Thu Mar 26, 2020 3:42 pm
[LuxCore][27.703] [PathOCLBaseRenderThread::0] Compiling kernels
[LuxCore][141.219] [PathOCLBaseRenderThread::0] Kernels not cached
It takes about 2 mins to compile the kernels at the very first run but it should happen only the first time
Posted: Thu Mar 26, 2020 3:47 pm
by pixel_peeper
B.Y.O.B. wrote: Thu Mar 26, 2020 3:28 pm
it's basically a repetition of the last few lines, like this, many many times, until 10 seconds of preview are over:
get_changes(): checking for config changes took 1.0 ms
get_changes(): checking for camera changes took 0.0 ms
view_draw(): checking for changes took 1.0 ms
view_draw(): session.WaitNewFrame() took 4.0 ms
view_draw(): session.UpdateStats() took 0.0 ms
view_draw(): framebuffer update took 20.0 ms
view_draw(): framebuffer drawing took 1.0 ms
view_draw(): showing stats in UI took 0.0 ms
view_draw() took 29.0 ms
sorry but it's too long also for this post:
Your message contains 122481 characters.
The maximum number of allowed characters is 60000.
I think that here is when everything stays freezed for a while:
[LuxCore][141.219] [PathOCLBaseRenderThread::0] Kernels compilation time: 113515ms
Posted: Thu Mar 26, 2020 3:49 pm
by pixel_peeper
I upload the file if you want, let me just remove all the logo and reference to the client brand...
Posted: Thu Mar 26, 2020 3:51 pm
pixel_peeper wrote: Thu Mar 26, 2020 3:47 pm
Well, but this is an OK refresh rate (35 fps).
Doesn't look slow to me.
This is the one-time kernel compilation. It happens only once for the viewport render (and once for the final render), then the kernels are cached and this step will take 0 time.
Posted: Fri Mar 27, 2020 9:26 pm
by pixel_peeper
the kernel compilation happens every time I switch to rendered view? I don't know why but it's still laggy, the shading process is very difficult and sometimes it freezes. I can barely guess how hard can be develope a render engine, mine are not complainings but feedback to develpe a strong and powerful engine ready for professional work, thank you for this awesome tool
Posted: Fri Mar 27, 2020 10:26 pm
The UI text "compiling kernels" is outdated, I have not yet removed it (it's a dev build after all).
You have to check the console log to see if it's actually compiling kernels (it should say "kernels cached" after the one-time compilation, which means it doesn't need a recompile anymore).
What hardware do you have?
Posted: Sun Mar 29, 2020 7:39 pm
by pixel_peeper
I have a win PC with Intel i7 8700K slightly overclocked, 16 GB 3000 MHz RAM and a GTX 1070 Ti
Posted: Mon Mar 30, 2020 4:44 am
by Odilkhan Yakubov
I've same problems. Is it possible don't compiling just once and not anymore? Like Cycles do this.
Posted: Mon Mar 30, 2020 9:01 am
Odilkhan Yakubov wrote: Mon Mar 30, 2020 4:44 am
Normally compil once for ever is for Luxcore 2.4 (just install a build)
