Page 3 of 3
Re: pathOCL turning singlesided meshes transparent
Posted: Wed Sep 11, 2019 8:04 am
How big is the scene as-is?
It would be really great to have a testcase of this problem, to find the real bug.
Posted: Wed Sep 11, 2019 8:06 am
So yes.. If I make all meshes of the table into a single one (so that the top isn't really open and singlesided) then everything works.
So... There is some issue with opencl and single sided flat meshes (I only saw this error on planar and open surfaces so far - even a single flat polygon) but it appears somewhat randomly so not sure what triggers it...
tables with meshes as separate parts
and merged into one
checked every single table, everything is fine now
Posted: Wed Sep 11, 2019 8:08 am
B.Y.O.B. wrote: Wed Sep 11, 2019 8:04 am How big is the scene as-is?
Pretty much everything is linked so I have no idea, main folder is 25GB but many things and textures are linked outside the main folder (could be another 20GB)
Posted: Wed Sep 11, 2019 8:17 am
ha..
got it...
here's a demoscene where opencl won't render the flat planes for me.
planes_bug.blend
(766.49 KiB) Downloaded 242 times
so it's set to render opencl and planes are invisible, if you switch to cpu they become visible
Posted: Wed Sep 11, 2019 8:30 am
by marcatore
something strange on it
OPENCL
added a solidify modifier to the first plane of the middle row
For an unknown reason the 4th plane of the middle row became visibile as well the third one row.
Screw modifier
Skin
Wireframe
Another attempt with Solidify after tried with the other modifier
Posted: Wed Sep 11, 2019 8:36 am
Yes, to explain a bit further
meshes on the rightmost side are a single mesh consisting of multiple planes
in the middle there is a single plane as object and others in the row are instanced
and on the leftmost side all planes are individual copies of the first in the row
Posted: Wed Sep 11, 2019 11:50 am
by Egert_Kanep
Tried your scene, none of the geometry is visible when rendering with gpu only. When using only cpu they are visible and when on both cpu ang gpu planes become semitransparent :D
Posted: Wed Sep 11, 2019 1:22 pm
lacilaci wrote: Wed Sep 11, 2019 8:17 am ha..
got it...
planes_bug.blend
Posted: Wed Sep 18, 2019 6:35 pm
by kintuX
Nice :)
