Ring on a small shrine - Rendered with Luxcore 2.4
Posted: Fri Jul 24, 2020 10:31 pm
by joyasrohrbach
Designed for an advanced jewelry tutorial with BLENDER 2.9 - rendered with LUXCORE 2.4
Post effects painted in Painter. Scene has been mostly sculpted.
NVIDIA Cuda usage has been notably improved in 2.4
4K Image
Re: Ring on a small shrine - Rendered with Luxcore 2.4
Posted: Mon Jul 27, 2020 12:07 pm
by sarmath
Beautiful
Posted: Mon Jul 27, 2020 12:14 pm
Really beautifull and complexe shape
. I think it deserve a bit longer render time the are part made too smooth by the denoiser(leaves area for example). As it is jewelry sharper reflection are needed.
Posted: Fri Jul 31, 2020 9:49 pm
by joyasrohrbach
Hi, thanks for your great comments.
That render got to 1200 samples, it is much the depth of field for the marco view making bluriness and not the denoising. The jewel is sharp, metal has roughness and bumps to make it artistically more interesting. This scene got selected in Blendernation weekly selection. I made a new version with smoke and particules rendered directly with LuxCoreRender 2.4 - I was very happy to use volumetrics and particules with Luxcore. Every particle became a light source thanks to the emision, and that gave the final composition more colors and made the scene really attractive.
You can check variants and the thread at
https://blenderartists.org/t/ring-on-a- ... es/1243187
Posted: Sat Aug 01, 2020 7:46 am
joyasrohrbach wrote: Fri Jul 31, 2020 9:49 pm
You rock
It should be in the gallery
Posted: Sat Aug 01, 2020 9:33 am
by Theo_Gottwald
Amazing realistic. The coloured smoke is a interesting highligt.
At the top of the Gem i would had expected a small reflection of something not just a white vertex.
Posted: Tue Aug 04, 2020 12:19 am
by joyasrohrbach
Theo_Gottwald wrote: Sat Aug 01, 2020 9:33 am
Thank you for your very nice comment. Yes, at the top... You can see the last update at
https://blenderartists.org/t/ring-on-a- ... es/1243187 - The top is still almost totally white but I did add a small color ramp from the left side.
Posted: Tue Aug 04, 2020 6:34 am
by Theo_Gottwald
Yes, that was just the missing dots ... now looks perfect for what it should be.
