Rendering in High Resolution for good Denoising
johannes.wilde
Post by johannes.wilde » Thu Feb 18, 2021 10:12 am
After some tests with different render sizes and settings, amount of samples etc. i am really impressed with the low amount of samples you can get away with, if you have enough pixels to work with for the Denoiser.
I rendered the image in 5760x3240 with the lowest amount of samples(32) for Cache Friendly Rendering.
Then i did some slight post production in RawTherapee and scaled the image down to 4k resolution.
The rendering just took me 8min 57sec on a RTX2080ti and a Ryzen 1700x
I will never again spend thousands of samples on a 1k image i think :idea:
patro
Re: Rendering in High Resolution for good Denoising
Post by patro » Sun Mar 21, 2021 9:00 pm
nice tip.. thanks for sharing ;)
Post by TAO » Sun Mar 21, 2021 9:09 pm
Nice trick, there is another approach too, when I want to create a big image with good quality. first, I'll cache the light with a small size image and use that cache to render a huge size image without actually light calculation. this trick will give you better results and also it is much faster.
Latest build Download link👇👇
https://forums.luxcorerender.org/viewto ... 378#p28378
johannes.wilde
Post by johannes.wilde » Tue Mar 23, 2021 4:51 pm
Cool!
Thank you as well! I will give it a try!
