LuxCoreRender v2.2alpha1 released
Re: LuxCoreRender v2.2alpha1 released
Post by FarbigeWelt » Mon Mar 25, 2019 11:55 am
B.Y.O.B. wrote:
Mon Mar 25, 2019 9:01 am
Can you upload the scene?
It shoul be in my first post as 7z File.
sanjinms
Post by sanjinms » Mon Mar 25, 2019 12:00 pm
So you probably ran out of (GPU) memory?
Hmm...I use I7(7th), 16gb of ram and GeForce 1070(8gb vram)
Post by B.Y.O.B. » Mon Mar 25, 2019 12:10 pm
A texture of size 7000x5000px needs about 400 MiB of memory (assuming it has 3 channels).
You could check the RAM usage when you try to use it, and check how much your scene needs without this texture.
Post by B.Y.O.B. » Mon Mar 25, 2019 12:15 pm
Sorry, my bad, totally forgot that.
Anyway, you can fix the problem by moving the texture in the Z direction (lower left):
sanjinms
Post by sanjinms » Mon Mar 25, 2019 12:17 pm
It happens even in startup empty scene even when I turn off openCL in both render settings and Imagepipeline. Of course, only if I using HighRes images.
Post by FarbigeWelt » Mon Mar 25, 2019 3:00 pm
😎 Thanks for this. I moved the objects away from 0,0,0 but did not think about to do it with local 3d mapping too.
Do you think this could be done internally a check against 0 and if true to move it automatically by a minimal offset? In my opinion the current behaviour of the software is not user friendly in borh cases:
- 3d position of objects
- 3d position of textire mapping
Because in both cases default is 0,0,0.
Regards
Post by B.Y.O.B. » Mon Mar 25, 2019 3:02 pm
As I said in an earlier post, we already do this internally and I could not reproduce your problem in a fresh scene.
No idea what was wrong in your scene, maybe some excessive scale or something else? Anyway, it already works user-friendly in a normal scene.
Post by FarbigeWelt » Mon Mar 25, 2019 4:44 pm
In a fresh scene. in a normal scene.
It is meant to be a freah scene, but I imported materials from 2.2 a0. Maybe this is a reason for the ‚unusual‘ behaviour. Does this mean I have to materialize from scratch for every older scene to use it with version 2.2 alpha1?
If yes, well this is not a big issue. But one have to consider this.
(How ever for mass creation of materials a kind of table based parser would be nice idea.)
Post by B.Y.O.B. » Mon Mar 25, 2019 5:12 pm
No, this should also work on materials saved with older versions.
pepe
Post by pepe » Mon Mar 25, 2019 5:31 pm
Any chance for a macos version?
I am contemplating future possibilities.
I guess the best os for blender and luxcore will be linux.
But what are the best price/performance hardware right now?
Edit
An i7 8700k with 32G of ram look like a good option.
