BlendLuxCore crash
BlendLuxCore crash
I am testing luxcorerender and I consistently crash it in 3 situation:
-copy paste from one instance to another
-open a new file while from another luxcore file (I mean not from start file)
-ctrl+z - when using undo
I am on windows with blendluxcore 2.2 alpha 0 blender 2.79 (last stable version)
Rendering some old file:
Re: BlendLuxCore crash
Might be this bug? https://github.com/LuxCoreRender/BlendL ... issues/148
I had not heard of this yet. Can you post a scene that shows the problem?pepe wrote: Sat Mar 23, 2019 2:13 pm -open a new file while from another luxcore file (I mean not from start file)
There have been some users reporting this as well (and I have seen it myself), but unfortunately I could not reproduce it reliably yet.
See viewtopic.php?f=4&t=798&p=10492#p10491
This happens to me too sometimes, but i don't exactly know how when or why. It's old bug 1+ years for sure.pepe wrote: Sat Mar 23, 2019 2:13 pm -open a new file while from another luxcore file (I mean not from start file)
I exit blender before open another file.
I dig it more to find out about the crashes.
Copy paste crash is indeed a blender 2.79b bug. I was coping from 2.78 and Ctrl+C works but when paste to 2.79 crash.
and Ctrl+C in 2.79b crash. The bug is somehow fixed in master but I like to find an win64 compiled version if somebody know that exit.
The other 2 crushes Ctrl+Z (undo) and opening another file is due to my file.
I append the objects and the camera in a new empty file and those 2 crashes no longer happen.
Like to upload the file but is too big (though I left just a cube, >13 MB - I like to send it to be able to investigate - the file have nothing else than a cube and a camera). It render ok but crash with undo and when open another file.
EDIT
Uploaded https://ufile.io/y01u8
EDIT
You could upload the file to http://pasteall.org/blend/ if you can share it publicly. Otherwise some filehoster would be an option and you can send me the link via private message.
Can't uploaded on pasteall but it is on ufile website.
See the link above.
See the link above.
I can reproduce the crash when opening another file while the "cube.blend" is open.
However it seems like a bug in Blender to me because it also happens when the BlendLuxCore addon is disabled.
I'll check if it still happens with latest master and 2.8, maybe they have fixed it already - otherwise I'll open a bug report with my findings.
I'll try to reproduce the undo crash tomorrow.
edit: Undo also crashes consistently, but the stacktrace also looks to me like a bug in Blender, not something to do with our addon.
Thank you for looking into that.
Th file should be under 1mb, and is over 13mb. There are information that should not be there.
If I append the camera and the cube in a new file there are no more crashes, neither with Ctrl+Z neither when I open another file.
Something is hidden in the file that make it crash.
Edit
The file start from a old cycles scene done with blender 2.72
Edit
I can reproduce both of your problems (open crash + undo crash), but it also happens in a factory-reset Blender and has nothing to do with our addon.
So I'd like to ask you to open a bug report over at https://developer.blender.org/maniphest ... it/form/1/ and report the problem there.
Here are my gdb backtraces, you can copy them into the bug report, they might help the Blender developers:
Opening another .blend file while "cube.blend" is open:
Moving the cube and undoing:
The backtraces are almost similar, I'm pretty sure Blender internally does the same things for opening and undo, and it crashes in the same code in both cases.
I could reproduce the crashes even with the latest master (2.79) and 2.80 buildbot builds (from today). OS also doesn't matter, happens on Windows and Linux.
Read blend: /home/simon/Downloads/cube.blend
Color management: scene view "Filmic" not found, setting default "Default".
Color management: scene look "Filmic - Medium High Contrast" not found, setting default "None".
[New Thread 0x7fffc75d9700 (LWP 30605)]
[Thread 0x7fffc75d9700 (LWP 30605) exited]
Read blend: /home/simon/Downloads/fire.blend
Thread 1 "blender" received signal SIGSEGV, Segmentation fault.
0x00000000032a5c2d in MEM_lockfree_allocN_len (vmemh=0xe7cf9a9f68) at /home/simon/programs/blender-git/blender/intern/guardedalloc/intern/mallocn_lockfree_impl.c:125
125 return MEMHEAD_FROM_PTR(vmemh)->len & ~((size_t) (MEMHEAD_MMAP_FLAG | MEMHEAD_ALIGN_FLAG));
(gdb) bt
#0 0x00000000032a5c2d in MEM_lockfree_allocN_len (vmemh=0xe7cf9a9f68) at /home/simon/programs/blender-git/blender/intern/guardedalloc/intern/mallocn_lockfree_impl.c:125
#1 0x00000000032a5c61 in MEM_lockfree_freeN (vmemh=0xe7cf9a9f68) at /home/simon/programs/blender-git/blender/intern/guardedalloc/intern/mallocn_lockfree_impl.c:135
#2 0x0000000002b9a6d4 in curvemapping_free_data (cumap=0x7fffcddbe748) at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/colortools.c:111
#3 0x0000000002b9a825 in curvemapping_free (cumap=0x7fffcddbe748) at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/colortools.c:128
#4 0x0000000002e12b31 in node_free_curves (node=0x7fffd7a56808) at /home/simon/programs/blender-git/blender/source/blender/nodes/intern/node_util.c:58
#5 0x0000000002cca8e0 in node_free_node_ex (ntree=0x7fffcddbe588, node=0x7fffd7a56808, remove_animdata=false, use_api_free_cb=false) at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/node.c:1726
#6 0x0000000002ccac7c in ntreeFreeTree (ntree=0x7fffcddbe588) at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/node.c:1826
#7 0x0000000002c6cafc in BKE_libblock_free_datablock (id=0x7fffcddbe588) at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/library_remap.c:823
#8 0x0000000002c6cc45 in BKE_libblock_free_ex (bmain=0x7fffcc413f08, idv=0x7fffcddbe588, do_id_user=false, do_ui_user=false) at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/library_remap.c:883
#9 0x0000000002c5b441 in BKE_main_free (mainvar=0x7fffcc413f08) at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/library.c:1172
#10 0x0000000002b66975 in BKE_blender_globals_clear () at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/blender.c:136
#11 0x0000000002b688c5 in setup_app_data (C=0x7fffe0087d38, bfd=0x7fffd80cf608, filepath=0x7fffffffdda0 "/home/simon/Downloads/fire.blend", reports=0x7fffcccb2c48)
at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/blendfile.c:219
#12 0x0000000002b68f0a in BKE_blendfile_read (C=0x7fffe0087d38, filepath=0x7fffffffdda0 "/home/simon/Downloads/fire.blend", reports=0x7fffcccb2c48, skip_flags=0)
at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/blendfile.c:376
#13 0x0000000001e55bb3 in WM_file_read (C=0x7fffe0087d38, filepath=0x7fffffffdda0 "/home/simon/Downloads/fire.blend", reports=0x7fffcccb2c48) at /home/simon/programs/blender-git/blender/source/blender/windowmanager/intern/wm_files.c:560
#14 0x0000000001e589c4 in wm_file_read_opwrap (C=0x7fffe0087d38, filepath=0x7fffffffdda0 "/home/simon/Downloads/fire.blend", reports=0x7fffcccb2c48, autoexec_init=true)
at /home/simon/programs/blender-git/blender/source/blender/windowmanager/intern/wm_files.c:1690
#15 0x0000000001e58c27 in wm_open_mainfile_exec (C=0x7fffe0087d38, op=0x7fffcc951688) at /home/simon/programs/blender-git/blender/source/blender/windowmanager/intern/wm_files.c:1749
#16 0x0000000001e510a4 in wm_handler_fileselect_do (C=0x7fffe0087d38, handlers=0x7fffd7b3e3b0, handler=0x7fffcc8a1e28, val=2) at /home/simon/programs/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:1884
#17 0x0000000001e51429 in wm_handler_fileselect_call (C=0x7fffe0087d38, handlers=0x7fffd7b3e3b0, handler=0x7fffcc8a1e28, event=0x7fffd9efa888)
at /home/simon/programs/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:1971
#18 0x0000000001e518e0 in wm_handlers_do_intern (C=0x7fffe0087d38, event=0x7fffd9efa888, handlers=0x7fffd7b3e3b0) at /home/simon/programs/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:2095
#19 0x0000000001e51b3a in wm_handlers_do (C=0x7fffe0087d38, event=0x7fffd9efa888, handlers=0x7fffd7b3e3b0) at /home/simon/programs/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:2173
#20 0x0000000001e526cd in wm_event_do_handlers (C=0x7fffe0087d38) at /home/simon/programs/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:2446
#21 0x0000000001e462c7 in WM_main (C=0x7fffe0087d38) at /home/simon/programs/blender-git/blender/source/blender/windowmanager/intern/wm.c:504
#22 0x0000000001e41295 in main (argc=1, argv=0x7fffffffe5b8) at /home/simon/programs/blender-git/blender/source/creator/creator.c:527
(gdb)
(gdb) bt
#2 0x0000000002b9a6d4 in curvemapping_free_data (cumap=0x7fffd8a2c208) at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/colortools.c:111
#3 0x0000000002b9a825 in curvemapping_free (cumap=0x7fffd8a2c208) at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/colortools.c:128
#4 0x0000000002e12b31 in node_free_curves (node=0x7fffcdf65808) at /home/simon/programs/blender-git/blender/source/blender/nodes/intern/node_util.c:58
#5 0x0000000002cca8e0 in node_free_node_ex (ntree=0x7fffd8a2c048, node=0x7fffcdf65808, remove_animdata=false, use_api_free_cb=false) at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/node.c:1726
#6 0x0000000002ccac7c in ntreeFreeTree (ntree=0x7fffd8a2c048) at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/node.c:1826
#7 0x0000000002c6cafc in BKE_libblock_free_datablock (id=0x7fffd8a2c048) at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/library_remap.c:823
#8 0x0000000002c6cc45 in BKE_libblock_free_ex (bmain=0x7fffcd77ff08, idv=0x7fffd8a2c048, do_id_user=false, do_ui_user=false) at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/library_remap.c:883
#9 0x0000000002c5b441 in BKE_main_free (mainvar=0x7fffcd77ff08) at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/library.c:1172
#11 0x0000000002b688c5 in setup_app_data (C=0x7fffe0087d38, bfd=0x7fffccae5a08, filepath=0x6d1aafa "<memory1>", reports=0x0) at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/blendfile.c:219
#12 0x0000000002b690b4 in BKE_blendfile_read_from_memfile (C=0x7fffe0087d38, memfile=0x7fffd801d958, reports=0x0, skip_flags=0) at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/blendfile.c:419
#13 0x0000000002b67a06 in read_undosave (C=0x7fffe0087d38, uel=0x7fffd801d508) at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/blender_undo.c:113
#14 0x0000000002b67f67 in BKE_undo_step (C=0x7fffe0087d38, step=1) at /home/simon/programs/blender-git/blender/source/blender/blenkernel/intern/blender_undo.c:245
#15 0x0000000002097049 in ed_undo_step (C=0x7fffe0087d38, step=1, undoname=0x0) at /home/simon/programs/blender-git/blender/source/blender/editors/util/undo.c:202
#16 0x0000000002097444 in ed_undo_exec (C=0x7fffe0087d38, UNUSED_op=0x7fffccaa7b48) at /home/simon/programs/blender-git/blender/source/blender/editors/util/undo.c:314
#17 0x0000000001e4f71e in wm_operator_invoke (C=0x7fffe0087d38, ot=0x7fffd9cd7e88, event=0x7fffd8d35a88, properties=0x7fffcc812f88, reports=0x0, poll_only=false)
at /home/simon/programs/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:1140
#18 0x0000000001e50e25 in wm_handler_operator_call (C=0x7fffe0087d38, handlers=0x7fffd8fa1c20, handler=0x7fffcc9036a8, event=0x7fffd8d35a88, properties=0x7fffcc812f88)
at /home/simon/programs/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:1782
#19 0x0000000001e5177c in wm_handlers_do_intern (C=0x7fffe0087d38, event=0x7fffd8d35a88, handlers=0x7fffd8fa1c20) at /home/simon/programs/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:2062
#20 0x0000000001e51b3a in wm_handlers_do (C=0x7fffe0087d38, event=0x7fffd8d35a88, handlers=0x7fffd8fa1c20) at /home/simon/programs/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:2173
#21 0x0000000001e52b18 in wm_event_do_handlers (C=0x7fffe0087d38) at /home/simon/programs/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:2539
#22 0x0000000001e462c7 in WM_main (C=0x7fffe0087d38) at /home/simon/programs/blender-git/blender/source/blender/windowmanager/intern/wm.c:504
#23 0x0000000001e41295 in main (argc=1, argv=0x7fffffffe5b8) at /home/simon/programs/blender-git/blender/source/creator/creator.c:527
(gdb)
Did you file the bug report? If not, I can do it.
