Comparison Between Lux and Cycles
rrubberr
Post by rrubberr »
I was interested today after downloading the latest beta of Blender 2.8, and thought I might try comparing it to Luxcore. I modeled a very simple 'Cornell Box,' just to test the performance in a slightly difficult lighting scenario, and the results were a bit interesting, especially when it comes to the quality of denoising.
Both examples were 128 samples, with the same size and type of light-source, the same hex-color values, and the same sobol sampler. The Cycles image was rendered with "Full Global Illumination" (128 light bounces), while the Lux scene used my default setting of 10/8/8/10 bounces.
The attachment Luxcore.png is no longer available
The attachment Cycles.png is no longer available
The top or first is Lux, the bottom or second is Cycles. The same scene can be viewed without the denoiser below.
Again, the top or first is Lux, the bottom or second is Cycles. The light appears brighter in Cycles because it does not have automatic camera exposure.
A couple takeaways are that Cycles has much more color noise, and OIDN is a FAR superior denoiser to pretty much all the competition.
What do you guys think?
Calling all Linux users: check out the new LuxRender 1.7 Flatpak! https://github.com/rrubberr/Flatpak-LuxRender
Light transport enthusiast - www.rrubberr.com
Re: Comparison Between Lux and Cycles
Don't think it is fair to compare luxcore to cycles with 128 path deph for cycles and just 10 max for lux. if you want good comparison try to simulate exactly same setting for each renderer : Cameera/light / engine.
rrubberr wrote: Thu Mar 07, 2019 1:29 am A couple takeaways are that Cycles has much more color noise
Try to use PhotonGI in the last v2.2alpha0, the result will embracing for Cycles :mrgreen:
But I agree with Sharlybg, can't you set the max. depth to 10 in Cycles ?
rrubberr wrote: Thu Mar 07, 2019 1:29 am OIDN is a FAR superior denoiser to pretty much all the competition.
Blender foundation isn't exactly new to NIV (Not Invented Here) syndrome. Oidn is damn good and cost nothing to integrate.
Dade wrote: Thu Mar 07, 2019 10:50 am Blender foundation isn't exactly new to NIV (Not Invented Here) syndrome.
When the Cycles denoiser was created, there was no OIDN (or BCD, or Optix denoiser).
B.Y.O.B. wrote: Thu Mar 07, 2019 11:21 am
When we integrated BCD, OIDN wasn't available too and so :?: Didn't we integrated OIDN :?:
Try to read the comments to the patch with OIDN support for Blender...
wasd
Post by wasd »
Cycles has no bidir, nor Metropolis. It's just of of league.
p.s. cycles has bump. luxcore has NO bump
Bump ?
Or displacement ?
S0rda
Post by S0rda »
I also noticed that in cycles the noise is suppressed much worse, and that, in fact, if the fireflies appear on the image at the beginning of the render, even 5k passes may not have any effect. While luxrender handles such moments much better. Especially when there are some reflections, causing metal glare or various refractions (caustics) of glass.
wasd
Post by wasd »
Sharlybg wrote: Thu Mar 07, 2019 1:35 pm
Bump ?
Or displacement ?
Bump. I cannot use height map reliably, it's something which pretty realiably (every single time) gives me ugly unpredictable result.
Don't have this issue. but most of the time unpredictable result come frome bad/disoder in object relative size. to solve it check your normal in edit mode. if they are not correct just Add a new mesh (cucbe/plane or whatever you want) and first select your problematic object and select the new added mesh then Ctrl +J. in edit mode delete new mesh verticles. this will reset your object relative size to make bump work better.
